12 Valve Tune up to tow HEAVY!
Old 08-15-2007, 08:30 PM
Big Blue24's Avatar
Ok, my bud found a forklift for his construction projects. It weighs 22,000 pounds plus a suitable trailer. What do we need to do to his bone stock 96' 2500 Long Bed 12 valve Auto.
I was thinking gauges, #10 plate, Block Wastegate, Valve Body, Triple Disk, Exhaust Brake??
What are your thoughts?
Old 08-15-2007, 08:40 PM
displacedtexan's Avatar
Get a dually. To much weight for a 250o to tow daily IMHO
Your mods plus a GSK and timing would take care of the power end of things I would think though.
Old 08-15-2007, 09:15 PM
Big Blue24's Avatar
It would be towed once or twice a month and left at the job till the next house is ready to frame. Would air bags help out much, or an add a leaf? It is the heavier duty 3/4 ton.
Old 08-15-2007, 09:16 PM
cumminsdriver635's Avatar
Gauges, Valve body, triple disc converter, #0 plate, 3k GSK, 17* timing. That right there will give you a great towing setup without having to worry much about EGT's. That is a lot of weight for a 3/4 ton, but those are the mods i would do to handle it power wise.
Eric
Old 08-15-2007, 09:34 PM
If he won't be towing it often/far he would be fine with the 2500, bags would be nice. I read it the first time and pictured him moving it almost daily.
I personally wouldn't want a 0 for that kind of weight.
Old 08-15-2007, 10:35 PM
I haul plenty with my #0 with no problems at all. I can let out of it a little if the pyro starts to climb rather than be running with less power all the time. I never had an EGT problem at all hauling with the 181 DV's and the 0 plate. 1300* was pushing it as hard as it would go. These 191's will bury the pyro, but it is easily just as driveable if you know how to control your foot. i dont run around wide open with a load anyways. Actually I usually run valet mode when im loaded.
Eric
Old 08-15-2007, 11:00 PM
My fear is a personal dislike of things that just anyone couldn't drive. I worry that someone else would have to drive my truck (I have no idea why) and wouldn't watch temps and such...
Plus plates affect the bigger pumps a lot more, not saying it wouldn't work great, just that I wouldn't want one.
Old 08-15-2007, 11:07 PM
Big Blue24's Avatar
Wouldn't a 10 be great, 100 even more power, but a zero, isn't that like running no plate? Or am i confused? 17* timing and the head will still stay put? I am a 24 valver so this stuff is new to me.
Old 08-15-2007, 11:18 PM
0 is the most aggressive plate you can get. The 100 has defueling at the bottom, the 10 has a 100 plate curve at the bottom, and some more defueling at the top end.
The farther the arm can travel, the more fuel.
Old 08-15-2007, 11:21 PM
I understand where you are coming from. My uncles have had to drive my truck before, but usually no one drives it but me. I have the Valet switch, which is good if someone else drive it though
Eric
Old 08-15-2007, 11:22 PM
17* is about the max I would feel comfortable with on a DD. But the higher you go the more bottom end you loose. I love mine at 16.5*
Old 08-15-2007, 11:23 PM
Eric
I want a valet before any other mods for that very reason.
Old 08-16-2007, 08:37 AM
Big Blue24's Avatar
I don't want to push timing too far but mileage when empty is a bonus, so where is timing set at stock anyway? Sounds like somewhere in the 16* range is ideal for a daily driver.
Old 08-16-2007, 09:54 AM
Muddin_dude06's Avatar
I would not go above 15* of timing IMHO if towing that heavy of weight. And if it was me I would just do a #10 plate, 15* timing and address the transmission. It isn't hard to pull that much weight, stopping it is the bigger concern. I loved the way my truck pullied with a #100 and stock timing, getting up to speed was much easie than now... Plus you break things when you tow heavy at higher HP...
Old 08-16-2007, 09:51 PM
Big Blue24's Avatar
So is stock timing around 14* then?
Quick Reply: 12 Valve Tune up to tow HEAVY!
