View Full Version : 12 valve to ford questions
swango
06-22-2008, 09:58 PM
i have a complete donor truck for a swap when i pull the 12 valve what do i need to keep there wires going to a harness on the firewall to the passanger side is that pcm for trans ??
im sorry if it seems like a stuped question but i dont know anything about dodge thanks more questions to come lol
Mo Smoke
06-23-2008, 05:25 AM
Keep the Fuel shutoff wiring and relays, grid heater wiring and relays, fuel bowl and wiring. Thats it.
BRUISER
06-23-2008, 07:59 AM
you can check out: www.destroked.com
they have a lot of info on fords that are converted
Mo Smoke
06-23-2008, 12:40 PM
[laugh]I know..I did 3 of them.
jimlj
07-03-2008, 11:29 PM
What year Ford? What year Dodge?
I have a '79 F250 with a '89 Cummins.On my truck, I kept the whole donor truck untill I got the engine running. I used the alternator, regulator and wiring harness. I kept the whole harness on the drivers side of the engine and spliced into it for fuel kill, KSB, oil pressure and water temperature. I also used the grid heater relays and wiring. Keep your donor untill you finish, not only do you need wiring, but there are tons of small parts you will end up using. I cant even begine to tell the times I went out to the Dodge to get a part
swango
07-05-2008, 06:41 PM
1991 ford 1995 dodge
vBulletin® v3.6.7, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
