11 second 1/4 tuning
Old 09-04-2007, 09:04 PM
OutOfSight's Avatar
What are the guys running 11's useing for tuning? I was planing on stacking my scary larry with a TST but now have mixed feelings after talking to some people. So what stack will get me their?
Old 09-04-2007, 10:27 PM
morkable's Avatar
I am running a hot edge, diablo predator, dr p predator combo for mid ish 11's. I think that with the new ppe tuner and the dr p unit I might be able to touch the 10's
Kevin
Old 09-05-2007, 01:05 AM
OutOfSight's Avatar
Is the Dr. P unit the hot version? Also any info on this PPE, are those the only 2 your running (or plan to run)? Also any 06 guys?
Old 09-05-2007, 05:49 AM
OT-OF-Here's Avatar
Dr. P
Kevin
Kevin,
What Dr. P are you running.
Old 09-05-2007, 10:45 AM
morkable's Avatar
just the out of box stage 4 unit.
Kevin
Old 09-05-2007, 10:58 AM
Sloverado's Avatar
I like my custom stage 5 from Dr. P
Old 09-05-2007, 12:06 PM
judge88's Avatar
tst, pressure( mp-8 or ez )smarty or bddl is proven. if using smarty run it on even #'s without timing if stacking with tst. let the tst due the timing. if stacking tst with bddl then get the adjustable timing on the tst and let the bddl do the timing. keep tst on lower settings, pressure on medium settings and smarty on # 8 or crazy larry with the bddl.
Old 09-05-2007, 10:27 PM
OutOfSight's Avatar
You say its proven, can i ask anyone what they run in the 1/4 with it(by the way nice numbers judge!)
Old 09-06-2007, 10:56 AM
Chris Blevins's Avatar
II stage 2 pump, 3 flows injectors, silver bullet, beta smarty, tst, fass 200 will run 12.04 to 12.12 all night long no pressure box.
Old 09-06-2007, 05:13 PM
judge88's Avatar
i ran 11.52 @118mph with whats in my sig. with 100% water injection.
tst standard version- 3/1
smarty 8 - no timing
ez -3
rail pressure never dropped below 22k the whole run. keeping everything the same exectp playing with the bddl instead of smarty i could not dip into the 11's. i have an 03 however so no scarry larry for my truck. just watch your timing. do not run your downloader timing and tst timing all the way up .
Old 09-07-2007, 03:51 PM
dani b's Avatar
I know NGM has ran 11.0 with the PPE along with a small shot of NOS, and has run 11.3 on fuel alone! I dont remember the combo for the fuel run, it was months ago.
Old 09-07-2007, 07:19 PM
nobody's Avatar
Question Sorry for the hijack.
ez -3
Congrats on the fast times and great dyno numbers!!!!!!!!!
Has anyone with an '05 made any back to back passes w/ Scarry Larry, and the latest version of Smarty? I am also looking for some newer programing.
John
Old 09-07-2007, 08:16 PM
Smokeitup's Avatar
From what I can recall Dr. Performance doesn't make a stage 4 for the 04.5 and up little own a stage 5.
Old 09-07-2007, 10:08 PM
lit up's Avatar
I ran the TST adj/timing and the Smarty 4.4 beta with the ramifier in the mix and with the tst 3/2 standard program/3 degrees and the smarty at #5 and the ramifier off ran 11.88, that's #2 only and 15-18psi launch.
Old 09-07-2007, 11:04 PM
SMOKIN-U's Avatar
if i'm not mistaken luken ran mid 12's with his 05 with scarry larry and tst. I am not for sure if he had a pressure box or not
Quick Reply: 11 second 1/4 tuning
