100% pure ditilled water for Summer?
Old 05-07-2011, 08:48 AM
tndiesel's Avatar
Anyone run pure 100% distilled water in their cooling system in the hot Summer months? Would it be okay to do this for about 4 months only then go back to 50/50 for the colder months?
Old 05-07-2011, 08:59 AM
spoolinup's Avatar
I would probably worry about corrosion with no coolant mixed with the H2O. Someone here will have a more detailed answer.
Old 05-07-2011, 09:10 AM
C Schomer's Avatar
You need additives. The nitrite and molybdate scavenge oxygen and passivate the system - put a protective chemical coating on the metal surfaces. The additives also boost the Ph, keeping it non-corrosive and helps keep the hoses from rotting. I run reduced glycol and use more DCA additive. Cummins can't give me a definate answer on if that's the right thing to do but they say.. yeh, it makes sense, it should work as long as I have the additives. Craig
Old 05-07-2011, 09:37 AM
tndiesel's Avatar
I guess I could just run 70/30 water to antifreeze for the Summer?
Old 05-07-2011, 10:18 AM
OOPS's Avatar
My question is why?
Old 05-07-2011, 11:48 AM
Administrator/Jarhead
madhat's Avatar
Hey, man...
The boiling point of water is 210*F, or 100*C.
You need the antifreeze to make the boiling temp of the water higher, along with all of the other additives that keep the cooling system from rusting out.
I'll try to find you some more info, but the world is at your fingertips with google...
Old 05-07-2011, 12:33 PM
tndiesel's Avatar
Originally Posted by madhat
Hey, man...
It's actually 212 degrees at standard pressure but who's counting...
Old 05-07-2011, 01:23 PM
pronstar's Avatar
Pure water can absorb more heat...
Race cars/bikes often run distiller water, but they add something like Redline's Water Wetter with it.
But race engines are rebuilt often. You need additives in an iron engine.
Water in a pressurized system boils at a higher temp that 212 so that shouldnt be an issue, as these trucks don't typically run over 220 degrees (at least I don't think they do).
Old 05-07-2011, 02:07 PM
C Schomer's Avatar
Increasing thermal efficiency and raising the boiler point are two different issues. The radiator cap also raises the boiling point. If the radiator is rejecting more heat you won't have to worry about the boiling point so much. Craig
Old 05-07-2011, 02:24 PM
madhat's Avatar
DOH!
Old 05-07-2011, 03:29 PM
anoldbiker's Avatar
I was told by a chemist a while back that using distilled water in the cooling system is not recommended. The distilled water will draw minerals from the block as time passes. It's best to use filtered water, which has minerals in it already and not draw it from the block.
Old 05-07-2011, 04:25 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
I will ask the same question asked earlier? WHY?
Unless you just happen to like corroded up parts and tons of rust in the water jacket, I can't think of a single sound reason to do it.
If you are talking about a trailer queen that only makes occasional passes up the strip then maybe you have a reason....beyond that I am not seeing what you are trying to accomplish
Old 05-08-2011, 10:22 AM
poor boy's Avatar
antifreeze
I think if you look on the container it says antifreeze/coolant. It tells you on there it is for boil over protection.
Old 05-08-2011, 04:29 PM
papaduck's Avatar
No one has mentioned that the HOAT coolant also prevents cavatation. Cavatation happens in a diesel engine. During the fireing stroke the cylinder walls will expand and then will contract so fast the the coolant will actually boil (not from heat) causing small bubbles. These bubbles then collaps pitting the cylinder walls. Over time this will destroy the engine.
If you do not plan to keep this truck for some time then forget all the above suggestions and pass the truck on to some unfortunate buyer.
53 willys
38
11-06-2008 11:18 AM
Tommy93w350
08-20-2004 10:06 PM
Quick Reply: 100% pure ditilled water for Summer?
