.093 tubes and lines?
any of you guys have any real hp numbers before and after tubes and/or lines?? add hp? lose hp? what'd it change? ive got a 6spd, so is it gonna lope? swapping an so pump into my ho this week, so im curious what more i would gain if i added those to the mix....let me know guys thanks -jake (and prices in a pm if you have any)
I am also curious about the line size, I am going to do a p-pump swap for pulling only street/super street truck what size lines should I be after and why?
I don't know if it is true or not but I have heard you cant just put an SO pump in place of a HO? I would figure it has something to do with the ECM.
My tow rig is a 3500 6spd HO, just curious what kind of mileage do you get?
yep that rumor is going around that you cant, but i verified with guys who have and that it has been done, and that it will work, before i jumped into buying one, ill let you know!!! my foot is always in it so its too hard to tell, sorry -jake
i have .084 lines and i beleive .093 crossovers with my newer vp. it idles rough kinda surges at low cruise speed and chugs a little when coming to a stop but all in all not to bad drivable sounds cool. it gets annoying though, all day especially in traffic. power is a little bit later in the rpm range it seems like. but not completely noticeable.
does it make more power? almost sounds like it makes things worse.
when you bought the larger lines and connector tubes I assume you were told there would be a power increase? how much did they say it would do? what is the theory behind doing this?
Registered
i ran the larger tubes for about a week. a buddy let me borrow them to see if i wanted to pay $150 for them, i was running ~530 hp and i couldnt tell a difference so i pulled them and shipped them back
the larger tubes and lines retard your timing. i doubt you will see a benifit unless you had a p pump or a monster vp then you will need the volume of the larger lines and tubes.
stuckey you are the man the lines retard the initial timing my my newer vp44 i had to go to larger lines and yes i picked up like 12 hp with them, the point of the larger crossover tubes is to have a resivor of fuel for the injectors. im not sure how that works but they did add power, but they do get annoying after a little while.
SINGLESTACK
05-31-2011 06:26 PM
