07 infinity system-add JL cleansweep
Old 12-20-2008, 03:18 PM
plug ugly's Avatar
So I have been driving the truck more, with the lower fuel prices. I hate my Infiniti system. there is NO separation, and it just sounds muddy and distorted.
Is the clean sweep a good option? I like the steering wheel controls and functions of the stock head unit, just hate the sound.
Im looking to add all new speakers and a rear sub. Should I just replace the headunit and start from scratch, or is the clean sweep a good item?
Old 12-20-2008, 03:30 PM
Shagginwagon's Avatar
I got the Laramie like you and I replaced the head unit, all the factory speakers and added a sub, components, and amps. Now it's a little too much---too loud.
Old 12-21-2008, 01:52 PM
jballou's Avatar
What clean sweep were you thinking about? Have you talked to any on the aftermarket installers to see if it would work well with Infinity?
I have been thinking about ditching the infinity as well, but like the basics and steering wheel stuff.
Old 12-21-2008, 02:15 PM
osiris's Avatar
I had the cleansweep for a while then i went and changed to a different head unit... The clean sweep worked well but it is kind of pricey. i still have the cleansweep in anyone is interested...
Old 12-21-2008, 04:40 PM
FYI--you can keep your steering wheel controls with a SWIJACK--- Steering Wheel Interface Jack. I have full use of steering wheel radio controls with my aftermarket Alpine W-205-- Here's a pic--
Old 12-21-2008, 05:45 PM
Blake Clark's Avatar
If your going to swap everything else out, go with a fresh head unit too. Aftermarket radios have so many more features over the stockers, not to mention better sound processing etc...
Old 12-22-2008, 08:36 AM
enafzige's Avatar
I used the cleansweep to interface with the the OEM head unit. I'm running separate amps, infinity perfect component speakers, JL 12W6 sub, etc. Sounds pretty good...
--Eric
Old 12-22-2008, 11:21 AM
rip 112's Avatar
IMO the best option for tuning a radio would be either a good screen, or an equalizer. All the screens I've had were really nice with the tuning features.
Old 12-22-2008, 12:19 PM
haloman's Avatar
Be thankful you have a double-din and can get some new options. i didnt have the Ifinity in this truck when I got it, but IMHO the Infinity system is barely adequate also.
If you want a little upgrade that sounds good
Get a new headunit.
5-channel amp to run all new door speakers and wiring and small sub. That should sound really good and not wreck the bank. That way all the factory stuff is left in the truck should you return to stock all the aftermarket stuff can be pulled out and just hook the stock stuff back up.
Old 12-22-2008, 01:42 PM
plug ugly's Avatar
Originally Posted by Shagginwagon
FYI--you can keep your steering wheel controls with a SWIJACK--- Steering Wheel Interface Jack. [/IMG]
only certain h/u's tho, and then you are talking $$$$
Highway 4x4
02-28-2011 06:21 PM
dodgemaniac
06-12-2007 08:21 AM
04ctd
02-04-2004 11:21 PM
moopa
13
01-05-2003 08:26 PM
Quick Reply: 07 infinity system-add JL cleansweep
