06 problems
Old 05-26-2010, 04:18 PM
Paul Marx's Avatar
06 problems
ran cylinder kill and #2 cyl not pulling any load or very little. Installed reman injector. Runs great above idle. has rough idle. reran cylinder kill. # 2 cylinder still not pulling a load at idle. Cylinder balance test showed # 2@106 rpm and all the rest@ 103 rpm. Any ideals.
Old 05-27-2010, 06:32 AM
BigDiesels's Avatar
not sure what you mean by 106 rpm? On my AutoEnginuity the balance test gives % I thought.
Anyway, the only thing I could think of is maybe a stuck / broken valve or rings. If the cylinder isn't holding pressure, it won't do anything if you cut it out. Just a thought...
Old 05-27-2010, 06:24 PM
NickBeek's Avatar
It has to be one of two things. Wiring to the injector, or mechanical problem with that cylinder. While changing the injector did you notice if any of the valves for that cylinder were lower then the rest?
DJ Turbo.
10-13-2011 09:11 PM
staken
03-05-2008 07:41 PM
95 Dodge
07-02-2006 03:28 PM
olgraybeard
03-24-2003 06:32 AM
Dwight
03-18-2003 08:14 PM
Quick Reply: 06 problems
