06 Hard to move from park, TDR mag - which connector to disconnect?
In the latest TDR mag, it describes the hard to move from park issue that I'm having, common fix was to remove the safety park connector from the steering column, I hear it click every time I put it in park and roll forward a bit.
I looked under the steering column and theres a bunch of connectors, which one should I disconnect, black one?
I'm having this issue also...I thought the issue was in the valve body, so I just deal with it. If it can be fixed by simply unplugging a connector, I'd like to know which one too...
The issue is in transmission were the selector moves to engage different valves for different passages. The selector likely has a sharp edge on the initial position of park. If you ever have your valve body pulled tell them about your problem and they can die grind the edge a little smoother.
However, the brake interlock can be a problem at times but I don't think unplugging it is going to help as I believe sits default is locked and needs power to unlock.
Set the parking brake. Take your foot off the brake pedal. Then shift to park. If I'm on a hill, I stop the gear selector in N for a sec, then shift to park.
I always put my truck in neutral, set foot brake, then put into park.
It makes no difference if you set the parking brake, don't set it, use the foot brake, chock the wheels, or even stand on your head whistling dixie.
Its not the parking pawl thats the problem and its generally not the cable thats the problem. If the trans comes out of park when you step on the foot brake, no matter how hard it is, the interlock is working. That being said I have seen people try to take it out of park BEFORE stepping on the brake and wonder why it was so hard and took so long.
Step on the brake for at least a count of 2 before trying to shift, if it still sticks its probably the detent ball in the VB has worn the casting oblong and is jamming.
Bad Ramer Jamer
06-21-2018 05:56 PM
wreedCTD
08-16-2007 03:56 PM
Buz
08-27-2005 12:18 AM
billyrae
09-02-2004 08:45 PM
