06 gauge question
Old 10-17-2006, 05:48 PM
Lrdchaos's Avatar
06 gauge question
Ok, now that the 06's have been out awhile, you guys have had a chance to install pyro gauges in them. I am going to be installing a isspro pyrometer, what wires (color if possible) did you connect to for power, ground and lighting. Thanks
Old 10-17-2006, 05:51 PM
P.J
P.J's Avatar
Where are you getting the gauge(s)? There should be instructions with it.
ON EDIT:Sorry, didn't read it right the first time, I see what you are asking now and I will sit by patiently until someone answers us, I mean YOU.
Old 10-17-2006, 05:55 PM
checkster's Avatar
the light I tapped into the dimmer switch next to the headlight switch. Next to that switch was another plug not connected to anything(think it was for push button 4WD(I have a manual transfer case) There was an ignition on wire there I tapped into.
Old 10-17-2006, 06:02 PM
rustyshakelford's Avatar
there was a harness that i used right next to the headlight cluster. i think it used for the power pedals. might be the same one. just break out the test light
brett
Old 10-17-2006, 06:18 PM
checkster's Avatar
yup right next to it........you're probably right
Old 10-17-2006, 06:38 PM
Lrdchaos's Avatar
What color was the wire for the dimmer switch? I see the wiring harness that is actually taped to the head light cluster it has a blue plug in adaptor. I will use that for power, but there are a number of wires comming out of the headlight plug. Thanks
Old 10-17-2006, 06:50 PM
displacedtexan's Avatar
Yeah P.J. start your own thread!
Old 10-17-2006, 07:02 PM
53 willys's Avatar
the dimmer wire is orange with a black tracer, but there is 2 or 3 orange with black tracers back there so you need to get your test light out and check for the one that lights up with the headlight/park-lights "on"
I think the blue plug is your trailer lights harness plug?
you may want to find a different power source.
Old 10-17-2006, 07:20 PM
P.J
P.J's Avatar
Sad part is I knew the answer, it's the same as it was on my 01.
You guys ain't seen nothing yet, I am ordering my gauges in the next week or so, I'm sure I'll be chok full o' confusion here soon.
Old 10-18-2006, 09:49 AM
checkster's Avatar
nah, i have an 06 and put gauges in mine 3 weeks ago, wasnt bad and it wasnt to hard. got them from dieselmanor......excellent package with everything needed.
mtl0727
10-12-2005 01:02 PM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
Quick Reply: 06 gauge question
