05 three years old and...
Old 05-12-2008, 02:26 PM
belgianmagic's Avatar
squeek,squeek,squeek... U-Joints already .....36,000 miles
climb under to have a look and DOGG ...the rear main or front of the
tranny (TC) has a MAJOR leak front of Bell Housing is covered...BUT not wet enough to tell what it is. Just had it in for Tranny fluid and filter change and they didn't say anything...
ANY IDEAS ??
Old 05-12-2008, 05:25 PM
XLR8R's Avatar
It's major leak but you can't tell what kind of fluid it is?
Check the oil level, as well as tranny fluid & engine coolant... have had all 3 of these drip on me while wrenching under the bellhousing.
Sorry to hear about your U-joints - are you sure that's what the noise is?
Old 05-12-2008, 06:10 PM
Jeff in TD's Avatar
There are two hose clamps on a 5/8 coolant line, down on the side of the engine by the turbo, which are known to start seeping after a while.
The result is coolant dripping off the bottom of the bell housing.
If there's any moisture there, try snugging those up.
Old 05-12-2008, 08:00 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Is your coolant bottle showing low? I would agree with Jeff most likely coolant leaking.
Old 05-12-2008, 09:16 PM
Shanajustin's Avatar
Same here. Tightened mine up, good as new.
Old 05-13-2008, 12:02 AM
XLR8R's Avatar
The CTD cooling system runs awfully high pressures.
Old 05-13-2008, 06:54 PM
ok... NOT MAJOR...But its all wet with dirt all stuck to it...its a farm truck and very dusty here in the spring
thanks for the tips I will check in the morning
Old 05-13-2008, 09:15 PM
Jeff in TD's Avatar
Is that what it turned out to be, then?
I just thought it might be one of the simple, known problems that would only take a second to check.
When my truck was dripping, I couldn't for the life of me tell where it was coming from- I was wondering about the head gasket- until I searched here and found several threads about that hose.
Old 05-14-2008, 08:16 AM
wish it was the clamps BUT...NOT
THAT IS A STRANGE PLACE FOR AN ELBOW though ! lol
chariotdriver
10-18-2008 10:50 PM
$oC@l CTD
07-18-2007 11:41 PM
robox
04-15-2007 08:01 PM
MCMLV
09-13-2004 09:45 PM
Quick Reply: 05 three years old and...
