04.5 no start
04.5 no start
have an 04.5 truck that won't start, cranks but no start, scan tool says no communication. any ideas? where is the pcm located on these trucks?
lift pump is in the tank, it will not cycle with key. I tried to bypass with jumper wire and can get the pump to work that way. I know this truck may need a recovery file, but need communication with the pcm first
Check your scan tool connection to the OBDII port. If you bent a pin (pretty hard to do but possible) you might get a com error. If everything at the OBDII looks good you may want to check the backplane and make sure everything is still connected.
CoolumConst
10-11-2008 10:00 PM
bfarrell
11-30-2005 03:23 PM
502502
11-27-2004 09:15 PM
