03 track bar
Old 05-08-2006, 07:37 AM
Hoss15's Avatar
03 track bar
I installed this a couple weeks ago. i can slide it back and forth on the bolt on the frame end. there looks to be too much room on each side of the bar end, where it connects to the bracket. also it looks like the bushing does not stay in the bar end completely. Did i install this wrong? are there suppose to be wshaers on both sides of the bar end?
Thanks,
Hoss15
Old 05-08-2006, 09:13 AM
rockwithjason's Avatar
Mine was tight on both ends. I can't see being loose on the axle end as being normal. There were no washers with the kit and I have never heard of anyone needing them. Start by checking the part to make sure it's the right one. After that check it against your old track bar. Measure both and compare. If you get different measurements call the place you got it from and talk to them about it.
CTD2001
08-22-2009 10:03 PM
Dinner
05-29-2007 02:02 PM
kwillis-a
01-25-2007 09:10 PM
dieselgeek
03-19-2003 09:15 PM
MAX340
13
11-02-2002 07:47 PM
Quick Reply: 03 track bar
