'03 electric window problem
My truck has a problem.I can control all windows from drivers side control.Occasionally the other 3 will not work from their individual switch. Acts like you have the window lock pushed.They hadn't been working for about 3 weeks and today...poof..they started working again.I'm sure it wont last.. it never does. Are these things run through the computer? Any ideas?
Thanks in advance
Thanks in advance
I had a problem with the wiring harness through the driver's side rear door that was causing me problems. Open the door and check the wire loom. Just pull it loose from the body and check to make sure the wires aren't broken or stripped. Lots of trucks have reported this same issue. If that isn't it then I have no idea.
Can the window lock switch only be replaced?Also looks like the window and power mirror unit in the drivers door would be expensive.Anyone know what a replacement "board" costs? How do you bypass the window lock switch?? I tried to take the board apart.Took all the screws out and it looks like it should fall apart...not happening.They must have some secret code to get it apart. Anyone ever get farther than me that came up with the secret code?
also the switch may have gotten wet, someone ever spill anything on it? or water get through the window? had the same problem with my 02 1500, bought a new switch, and poof, fixed....
It's the drivers side power window switch. (all one piece.) I have two 2003 dodges.A Ram and a Durango and they both were doing same thing you described.
I bought them at the dodge dealer,$114.00 each. same part# for the ram and durango. The wife asked the parts dude if this is happening alot. He said that he had not heard of any issues. They're full of it!
Diesel Girl
18
10-06-2013 03:03 PM
Bowser50
01-27-2010 09:46 AM
cj5er
12-20-2009 09:19 PM
bigbaddiesel
05-31-2003 03:30 AM
