03 Ball and axle joint replacement.
Old Feb 23, 2008 | 04:42 PM
C/PRD/'s Avatar
I posted this in the emergency section also. I have my passenger side tore apart on my 03 and I cannot remove the hub assembly. Does the entire axle shaft have to come out on these AAM's or what. I have every bolt out of this thing and it just wont budge. Do I need to pull the diff cover and remove some sort of retainer or what? Thanks
Old Feb 23, 2008 | 04:48 PM
booman70's Avatar
You need to push it out form the backside. Put the four bolys back in almost all the way then using a extension between boly abd axle housing use power steering to press bolts pushing bearing assemnly out do one bolt at a time rotating around and backing the bolts out a little more and doing it again till you can remove
Old Feb 23, 2008 | 04:55 PM
C/PRD/'s Avatar
Thanks alot Booman.
Old Feb 23, 2008 | 06:02 PM
C/PRD/'s Avatar
What options do I have for manual locking hubs to put in this big piece of $h!t. I am begining to hate this truck! Is there a servicable bearing for these things that doesn't rust solid like these?
Old Feb 23, 2008 | 06:45 PM
booman70's Avatar
Heres the options I know of http://www.solidaxle.com/ProductCart...?idCategory=17
http://emsoffroad.com/shop/index.php...82f2832233bcc9
https://store.dynatrac.com/merchant....y_Code=HUBKITS
Old Feb 23, 2008 | 07:16 PM
C/PRD/'s Avatar
Holy cow I can't afford those! I put the beast back together and ordered 2 front hub assembly's for the next go at it and I am just gonna put new back in. I guess that's just the way it goes on a 180k mile truck.
72dart
Jun 19, 2012 10:42 PM
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
