0267 boost code
Old May 10, 2004 | 09:08 PM
72dart's Avatar
0267 boost code
Help!
My truck is defueling and the check engine light is on.
I had the guy scan it for me and it said low turbo boost input circuit. The code, I think is 0267 or 0237. I changed the IAT and MAP sensors, but no dice. Hope someone can help on this. Thanks!
Old May 10, 2004 | 11:40 PM
billg's Avatar
Hello 72dart and welcome to the site. Sorry your first post has to be up here. It would be a good idea to fill in your Signature with the details of your truck so people who know the truck can chime in and help. I will assume a 24v.
P0237----Map Sensor Voltage Too Low---Map sensor voltage input below the minimum acceptable voltage.
This is saying the voltage coming back to the ECM is lower than it would be at no boost. I would check all the connections real good. Do you have an Edge or other box? If so make sure all the connections are good and tight I would disconnect and reconnect them. I would also check and make sure all my grounds are good and clean.
Hope this helps.
jmccart
Apr 5, 2011 06:13 PM
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
