02 Slow go for 5-10 min
Old 09-21-2008, 10:13 PM
oilbob's Avatar
Just purchased a 02 2500 with 100,000 miles. Problem - start up and drive for the first 5 -10 min and will not pick up speed. Eng will build rpm but will not go. After 5-10 min will start to perform proporly. Do not know if time related or warm up. Trans or Eng problem?
Old 09-21-2008, 10:33 PM
brshhog's Avatar
have you checked the trans fluid level? that would cause those symptoms.
Old 09-22-2008, 08:08 AM
j-fox's Avatar
Your post is so vague it is tough to help you without having the truck here in front of me.
Has the fuel pressure been checked? When has the fuel filter been changed?
It the trans slipping ? If so, start it, put it in neutral for 1 minute, then try to drive away. Did that help it?
Does it have any gauges on it like, fuel pressure, EGT, or boost?
You can cycle the key, on/off/on/off/on and any codes will be read in the odometer window. Wait for the miles to re-appear, but write them all done.
What are those codes?
Old 09-22-2008, 09:09 AM
19Fury69's Avatar
Also if you fill out your signature, it would really help diagnos any problems
JDG
11-18-2004 12:41 AM
wengerda
06-24-2004 09:26 AM
shortycattleman
05-12-2004 09:30 PM
Arkansas
02-19-2003 11:52 AM
Quick Reply: 02 Slow go for 5-10 min
