02 Blowin White Smoke
Old 07-07-2007, 10:56 PM
mattbotkin's Avatar
Thank you all for the help with my cab light install. Now I have a real problem. At highway speed my truck will cut out on me and not pick up RPMs until I let up on it or kind of pump the pedal. But then it will run fine for awhile but it may do this for a couple of minutes. I changed the fuel filter twice and it seemed to run fine for about 50 to 100 miles both times and then go right back to the same old. Also, when it's at idle and you race up the motor it blows a lot of white smoke and will crack and pop out the exhaust until about 2 grand or better. Any help would be greatly appreciated.
Old 07-07-2007, 11:19 PM
Big Blue24's Avatar
Fill in your signature so we know what you have done to your truck as far as modifications. Is your truck stock?
Old 07-07-2007, 11:21 PM
Big Blue24's Avatar
To fill in your signature click on the User CP link on the upper lefthand portion of the page. How many miles are on your truck? Is it all original parts or have some things been replaced? Are you going through any coolant? Is the truck down on power?
Old 07-07-2007, 11:42 PM
wurkenman's Avatar
Hate to tell you this, but you are experiencing the "dead pedal". Look into getting a vp44 soon. Not much can be done to save it at this point.
Old 07-08-2007, 12:50 AM
Big Blue24's Avatar
You could have other problems, but if you are not going through coolant or oil and you are down on power when the smoke occurs, i'd second the VP 44 failure. That's why I wanted to know your mileage, recent repairs, etc. If you just changed the VP out like ten miles ago, I would be reluctant to jump to that conclusion.
Old 07-08-2007, 01:14 AM
PourinDiesel's Avatar
Injection Pump.
Old 07-08-2007, 07:02 AM
Registered
blackdiesel's Avatar
check your cdes with the key, I say you will get a 0216. and a new vp44
Old 07-08-2007, 12:36 PM
mattbotkin's Avatar
What is a VP 44 and about what is the going rate for one? Also what will it take to install this.
Old 07-08-2007, 12:53 PM
Registered
that's your injector pump, and there about 1050, and theres a video on how to put one on, if you seach for it you will find it.
Old 07-08-2007, 03:09 PM
Big Blue24's Avatar
No warranty on that truck?
mattbotkin
07-09-2007 09:23 PM
mattbotkin
07-08-2007 03:20 PM
howe719
08-14-2006 08:18 AM
redneckdr
10-11-2002 08:19 PM
Quick Reply: 02 Blowin White Smoke
