'01 Steering Question
Old 07-27-2005, 09:29 PM
tywebb3's Avatar
My steering seems to be a bit "loose" and I feel a slight "clunking" in the steering wheel when I am driving at times. I notice it more on rough roads than others. When I grab the linkage between the steering column and the steering gear box it rotates left to right a lot with the motor off. Is this the slop that I am feeling? Is there a way to tighten the steering gear box or does it need to be replaced. I just had the truck state inspected and all of the ball joints passed.
Thanks for any help
Old 07-27-2005, 09:49 PM
BigBlue's Avatar
There is a way to tighten the steering box. I think there's a how to in the tech section. Make sure your wheels are perfectly straight and don't tighten it but maybe a 1/4 turn at a time. Otherwise you could crack the housing so I'm told.
Old 07-28-2005, 11:43 AM
vssman's Avatar
While your at it - Look at the sector shaft (output shaft) on the box as you gently rotate the steering shaft back & forth. That sector shaft has been known to wear causing it to move front/rear before it rotates = play in wheel.
skindaddy
08-19-2009 08:51 PM
ocsurf16
03-13-2006 09:24 PM
unioncreek
06-29-2005 02:00 PM
OHFarmboy
02-25-2005 11:30 AM
06-05-2003 09:27 PM
Quick Reply: '01 Steering Question
