will 01 1500 cab swap onto my 97 2500?
Old 06-26-2008, 07:04 AM
horselady's Avatar
Found a wrecked 01 1500 club cab with the suicide doors. My interior on my 97 is crap, also would love the exra doors. Will it bolt up??
Old 06-27-2008, 08:55 PM
dozer12216's Avatar
Doubt could be that lucky!! Different cab length(???) sheet metal diferent and more.
Old 06-27-2008, 09:20 PM
seahawkdodge's Avatar
If you have a club cab, the length should be the same. I can't guarantee it, but I'm pretty sure the cab itself wouldn't be an issue.
The issue, however, would be that the instrument panel would have to be swapped in from your diesel, and the wiring is different. The 01 will have a different PCM, and the wiring would need to be swapped out with your 97.
I'm sure there is more to this as well...
Old 06-30-2008, 02:56 PM
horselady's Avatar
I'm going to look tonight. If nothing nothing else, the interior, tail gate and misc trip is worth what they want for it...
I expect to have to change the harnesses and electronics.
Old 06-30-2008, 05:51 PM
JHew84's Avatar
Take some measurements of your body mounts and go compare. From what I remember reading the frames are pretty different between the 1/2 and 3/4 tons so I would lean towards no, but the body mounts could be the same.
1stgendreamer
02-04-2015 08:03 AM
freight train
08-05-2011 04:57 AM
Adam3291
02-16-2008 07:52 AM
Trebor
11-26-2006 06:53 PM
signature600
12-14-2004 06:05 PM
Quick Reply: will 01 1500 cab swap onto my 97 2500?
