Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 06-06-2009, 05:46 PM   #1
64camo
64camo's Avatar
Anyone near Friona Tx and shift problem
This is on a 92 w250. When I accelerate rapidly the speedometer goes to 50 and then drops off and the trans won't shift till I ease back on the accelerator. The previous owner has put a small bolt in the gap that should be in the TV cable and has replaced the o/d switch with a toggle switch. He said the trans was rebuilt by AAMCO. Any suggestions? And if anyone is close by, I would like to talk to them.
__________________
92 W250 4x4 Reg Cab
2007 Quad Cab Laramie 4x4 6-speed DRW
Summerville SC
64 El camino
Rigid Chopper (Suicide Ride)
64camo is offline   Reply With Quote
Old 06-06-2009, 08:11 PM   #2
wannadiesel
You mean the speedo drops to zero after 50?
__________________
Faith
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner.
390 HP/800 TQ on #2 only, 413 HP/852 TQ w/ water/meth - needs more air!
Dead KDP's = 72
wannadiesel@dieseltruckresource.com
wannadiesel is offline   Reply With Quote
Old 06-06-2009, 08:15 PM   #3
64camo
64camo's Avatar
Yes, the needle waivers and then falls.
Old 06-06-2009, 08:17 PM   #4
wannadiesel
Sounds like a VSS problem. Make sure the drive isn't stripped and that the VSS is tight.
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
