Thread Tools | Search this Thread | Display Modes |
#1 | ||
Anybody made their own eliminator pipe?
__________________
2003 2500 2wd SWB Quad Cab Laramie, 305/555, NV5600, 3.73LS, Line-X, Westach boost/EGT combo gauge, PML diff cover, Airbox mod, Hurst 6spd Shift ****, Adjustable boost elbow, Toyo OC AT 285/70/17 E, Daystar 1.5" lift, Monroe Reflex, Raptor RP100, Lazarsmith Intake Horn, HID SMARTY Sr./Van Aaken C3.2 |
#2 |
Re:Anybody made their own eliminator pipe?
Some people have done it. Problem is finding something the right size. A piece of 5" pipe is too small. I think a PVC pipe connector for 4.5" or 5" (not sure of the size) will work. The outside dimension is the critical one.
Another idea is to remove the vanes from inside the factory pipe. Only a problem if you plan on re-installing it for some reason and want a factory look.
__________________
2004 Dodge 3500 4x4, HO, 6spd, Flame Red Sport |
#3 |
Thanks for the info.
I want to keep the baffle pipe intact just incase I don't like the results. I'm trying to contact a local muffler shop that has done some custom work for me in the past to see if they have 5" pipe that can be enlarged to 5.25" OD. MikeyB |
#4 |
contact member "Mark thomas", theres a POST started by him about this. he made me one too, sorry, no pic of mine. goto members photo`s, i think HE has a pic of his.
__________________
2003 High output, 48re-4X4, quadcab,SWB, |
#5 |
I assumed you meant the piece of pipe in the intake system between the filter and the turbo that has the vanes in it. Replacements for this piece are being called eliminators as well as the muffler eliminators (both pieces being sold by Geno's). My previous post relates to the intake eliminator pipe, not the muffler (obviously PVC wouldn't be used in the exhaust system).
#6 |
I went to Home Depot today and bought a 4" PVC coupler which has an outside diameter of roughly 5". It is too small. I ended up using a Sawzall to cut into the vanes on both ends and the using a hammer and chisel to break the vanes to get them out. They are probably in there for a reason, but oh well. A smoother flowing pipe would be a better choice, but this is only temporary. I plan on installing an AFE system from Diesel Dynamics and it comes with a piece to replace the pipe.
#7 |
what is the benifit of this ELIMINATOR pipe???
__________________
04, 2500 QC, SLT, LB, Almond pearl, HO CTD, Automatic, Leather interior, Sliding rear window, Heated mirrors, Fiberglass top all windows open, Custom Fishing Rod racks. |
#8 |
The eliminator pipe replaces the intake pipe that has the vane inside to reduce the turbo whistle.
MikeyB |
#9 |
I have been using a piece of 6" long 5" diameter exhaust pipe, a little bit small but clamps down nice and tight.
__________________
2002 Graphite 4x4 QuadCab Auto w/ mods |
#10 |
If you know someone with a fab shop and a small roll, they should be able to roll up the right OD out of flat stock. just have one seam to weld
__________________
03 3500 DRW HO 6spd ,Smarty/TST/EZ,4"exh,HTT62/65/12 ,Scotty RAIII, fass 150gph,sb dd sprung hub,fluid dampr |
#11 |
Location: Adirondacks of New York and Daytona Beach FL.
__________________
2011 - 2500 Laramie CC 2WD Limited Slip 3:73, Bright Silver, Tinted Glass, Silver Vent Visors, Sirius Radio, Stainless Steps, Aluminum Alloy Wheels, Husky Mud Guards, Power Sliding Rear Window, Century Fiberglass Tonneau, Brake Controller, Remote Start, Alarm, Navagation, back up camera, 38 Special S+W Mod. 642-Glock 27 .40 Cal. Crimson Trace Laser Grips-Have a nice day! OH Yeah 2010 HD-Streetglide, Patriot Guard Rider |
#12 |
does anyone know exactly what the OD is?
im too lazy to go take mine out and measure it :
#13 |
[quote author=Agades link=board=49;threadid=22956;start=0#msg217751 date=1070496603]
does anyone know exactly what the OD is? im too lazy to go take mine out and measure it : ![]() [/quote] It's about 5.25" OD. MikeyB |
#14 |
OK....5.25 OD
How long should I make it? |
#15 |
[quote author=Hairy1 link=board=49;threadid=22956;start=0#msg218021 date=1070548580]
OK....5.25 OD How long should I make it?[/quote]Low long? Take the OEM out and measure it twice. I've seen a picture of one online from a guy who made it out of PVC.
__________________
Chris '03 2500 SLT QC 4x4 short bed, 305/555 HO, NV5600, 4.10LS, 4" SS exh; H2/35's, Smarty Jr. '06 VW Jetta TDI, 5-speed '01 VW Golf TDI; 2 Door, 289K, 5-speed Maryland DTR Chapter #33 Feelings of inferiority and superiority are the same - they both come from fear |
| Display Modes | |
