Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register Forgot Password?
submit to reddit
Thread Tools Search this Thread Display Modes
Old 12-13-2010, 02:04 AM   #1
EdmontonCanada
EdmontonCanada's Avatar
Any such thing as Undercarriage Cover?
On some cars there is a plastic mold that covers the underside of the engine, usually for two reasons - protection and aerodynamics. Does anyone know if there is aftermarket part for this since there is no oem option?
__________________
2006 Megacab (White): Garrett Stage 3 BB Turbo, Banks Intake w/Scoop, DiabloSport Programmer w/PowerPuck Extreme, AirDog Fuel Pump, Banks Exhaust Brake, AFE Manifold, 5" Dual Magnaflow Exhaust, Mag-Hytec Diff Covers/Tranny Pan, Carli Starter Suspension Kit w/ Carli Long Travel Air Bags & Carli Chrome-Moly Ball Joints, Katzkin Leather Interior
EdmontonCanada is offline   Reply With Quote
Old 12-13-2010, 08:38 AM   #2
Rednax
Rednax's Avatar
Search "belly pan" on Ecomodder.com (all DIY). As to aero, it appears that open screen material may serve the same purpose.
Coroplast is the material of choice for inexpensive DIY (to see what works), and there are several excellent threads on the subject (the gains are real).
http://ecomodder.com/forum/showthrea...cks-15230.html
If my understanding is correct one can "seal off" the area underneath (from the front wheels back) from body outer edge to frame-rail for a benefit. (Parallel to ground or chassis)
Side skirts are also of benefit; again, if my understanding is correct, keeping air from crossing underneath vehicle promotes "clean" aero. (Extending downward from body edge towards ground).
On the front end extend the air dam down some to channel air "around". (I've made measurements of truck air dams in a parking lot and found none -- stock -- lower than 7" clearance). On my stock 2WD the air dam has 10" clearance. Somewhere over there I have seen the comment that front air dams need (given a stock height car, say) only channel air away from front end components (spoiler on front axle). Etc.
http://ecomodder.com/forum/showthrea...ckup-3171.html
A comment by Big Dave is (roughly): "Every time I improve aero I can tell by how much quieter it becomes" (FORD SuperDuty 7.3 averaging above 25-mpg, all miles).
For a pickup the best, first, aero improvement is the bed. A tonneau cover, a close-fitting cap (Aerolid), or DIY of same (great threads on this).
As a grille block is problematic on a diesel, then it may be that a MOPAR Winter Front can be used for some "aero" qualities along with some applied-to-the-front-of-the-grille-mesh "winter covers" (Cloud Rider and others; or, DIY from Lexan). I'd try the outer (upper) cover first.
If the questions concern N-V-H (Noise-Vibration-Harmonics), then investigate the TSB on door seals for some years of 3rd Gen (and/or adjust door striker), plus:
http://www.carsondodge.com/forums/showthread.php?t=67
http://www.fluidampr.com/CUMMINS.htm
http://www.balancemasters.com/driveshafts/index.html
http://www.dieseltruckresource.com/d...0&postcount=13
http://www.atpwrap.com/html/dodgeram.html
http://www.dieseltruckresource.com/d....html?t=145241
Tire tread design is the biggest NVH problem to solve. And adjust pressure according to Load Range Tire Chart to exactly meet scaled weight (neither over nor under Chrysler specs). Plus brake rattles and other loose componentry.
__________________
2004.0 DODGE Ram 555 CTD QC/LB 2500 2WD/NV-5600/3.73. 7,360-lb. Stock. 180,000-miles @ 4,625-hrs = 39-mph; 15-cpm fuel cost solo, 25-cpm towing.
Rednax is offline   Reply With Quote
Old 12-13-2010, 10:24 AM   #3
EdmontonCanada
So who sells the Belly Pan for our trucks?
Old 12-13-2010, 07:28 PM   #4
Rednax
Rednax's Avatar
D-I-Y, Inc.
Is it about aero for mileage, or for sound?
Old 12-13-2010, 08:13 PM   #5
EdmontonCanada
Sound. I'll modify it if need be, if possible.
Old 12-13-2010, 09:08 PM   #6
EdmontonCanada
Ok...was that a joke that went over my head? DIY=Do It Yourself, or is that a real company? LOL!
I tried googling it...couldn't find jack!
Old 12-14-2010, 05:08 PM   #7
moorepower
moorepower's Avatar
Just don't forget, that with even a little room, snow will get in them and can pack it tight, creating more problems than you solved. Possibly in Canada you don't see snow however!
__________________
Pat Moore
moorepower is offline   Reply With Quote
Old 12-15-2010, 02:53 PM   #8
EdmontonCanada
You're right. Gotta watch how I park it in my igloo!
No, I had a sports car I drove in winter. Had a belly pan. No problems.
We do have something called a "r-o-a-d p-l-o-w".
You should Google it.
Old 12-15-2010, 04:36 PM   #9
moorepower
moorepower's Avatar
When I used to work on over the road trucks, I saw some issues with snow packing tight in the frames and around side skirts and fairings. It was from the powder that they kicked up going down the road. Some of them would not thaw unless left in over nite.
Old 12-15-2010, 05:07 PM   #10
EdmontonCanada
I have a heated garage... I mean igloo!
Old 12-17-2010, 02:49 PM   #11
Rednax
Rednax's Avatar
Yeah, I was pulling your leg about DIY, Inc. (There probably is some company out there with such a name). If you'll read up -- and post your questions on Ecomodder -- about belly pans, etc, for trucks you might find responses smarter than mine. I have seen at least one reference to using a screen material (think expanded metal) as the air flow is about the same as with a non-pervious material.
But this may not render appropriate sound reduction. Ask, as someone may have already tried it (weirder things have . . . . )
I would think ATP, Inc for drivetrain noise stuff, and looking at the wheelwells for much of the road noise problem would be good once past tires.
The FORD guys have a thread out there about using silicone surgical tubing to beef the innards of weatherstripping to cut wind noise. And there's a DODGE TSB on the same subject.
Most of all, don't think that all problems are hearing related. Noise-Vibration-Harmonics are inter-related. I've been in vehicles that tested louder but didn't seem like it as the vibrations were much lower than a similar vehicle.
Why not try automatic wheel and driveshaft balancers, and have your shop loosen up the motor mounts to have it re-settle (and the rest of the Carson Dodge link rec's). Then door/window seals. That's where I'd start.
Let us know what you find; keep this thread going!
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Contact Us - Dodge Diesel - Diesel Truck Resource - Cummins - Archive - Privacy Statement - Terms of Service - Top
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
