Thread Tools | Search this Thread | Display Modes |
#1 | ||
Another Getrag Lube Question
__________________
Even in a bone-stock truck, a FUEL-PRESSURE-GAUGE is the first gauge you should install. Splice an in-line fuel-filter AHEAD of the lift-pump and carry a few spares. Blue MOPAR Voltage-Regulator = P3690731 #1 MY TRUCK = 1985 F-350, W/1989 Cummins, 5-sp. Getrag, Dana 70 3:55 #2 HER TRUCK = 1991.5 D-250, LE, I/C Cummins, auto #3 SON'S TRUCK = 1990 W-250, Cummins, 5-sp. Getrag, 3:54 #4 TRUCK = 1991 D-350, LE, Cummins, 5-sp. Getrag, 4:10 |
#2 | |
Quote:
I thing that thay are a blend of syn. the most expencive is you Full Syn.
__________________
91.0 non intercooled 3/4 ton 5sd ex.straight piped HX35, timing bumped 1/16...Pump mods have started Full power screw1/2 max with out removing the collar. Gear Vendor over drive! Finally finished 2nt gen intercooler turbo and Coolertubz, By Tim (TWorline)" write-up here:http://www.dieseltruckresource.com/d...d.php?t=186908 |
#3 |
Those three are all fully PAO-based synthetics. The EP has a more robust add pack intended to support long drain intervals for the engine oil. The 5w30 T&SUV is supposed to have an add pack aimed at gasser trucks and SUVs, "not" diesel rated like the old 5w40 T&SUV. The lower priced stuff is the original formula for use in any gasser.
If I was splurging on a good syn oil for the rag, I'd go with something like RP synchromax, of a boutique flavor from SF like their MTL-P. 10w30 or ATF will work OK, but there are alot better things out there if you're going to get into that price range. |
#4 |
Plain jane Mobil1 synthetic is fine. Those others are the same, only with extra additives or whatnot. Not necessary for the ole gutbag.
__________________
Bill Gilbert 85 D350 crew with 90 6BT intercooled Getrag 3.07's 93 D350 single cab Getrag 3.54's |
| Display Modes | |
