Go Back   Dodge Diesel - Diesel Truck Resource Forums > General > Natl. and Regional Chapters / Special Events > CADTR #27
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-30-2008, 12:55 AM   #1
Dennis
Question Where am I?
If Chapter 21 is Nor Cal, Chapter 24 is So Cal, where does Chapter 27 cover?
__________________
2001 Ram 4X4 Quad Cab Long Bed * 1971 Bronco
Dennis is offline   Reply With Quote
Old 11-30-2008, 11:19 PM   #2
Woodchuck61
Woodchuck61's Avatar
Good question. Where are you?
__________________
'04 2500 4x4 Regular Cab Long Bed Laramie, HO 305 w/48RE and 3.73 gears, Smarty stacked with PMCR w/R49 AP, FASS, aFe Stage 2 intake, HTB2 62/65-13 S.S., CFM Plus air horn, ATS exhaust manifold, 04.5 4" elbow and down pipe, Aeroturbine 4040L, and MBRP 4" exhaust, DIY full billet trans, Suncoast VB, ATS 5 star TQ + Co Pilot, Snug Top shell, Weld wheels with 35" Toyo MT, Kore Pace suspension. 511 HP, 984 TQ, 13.635 ET @ 99.44 mph, at Crude Drags 2 in Bakersfield.
Woodchuck61 is offline   Reply With Quote
Old 12-09-2008, 03:08 PM   #3
Dennis
I am near Sacramento.
Old 12-09-2008, 10:24 PM   #4
doznfire
doznfire's Avatar
Chapter 27 was covering the central coast. That is where Tye was from until he moved to Colorado.
__________________
1966 chevy 12v cummins. 1 ton 4x4, 6spd, 370's, 16.5*,4000gsk, 60# springs, tweaked pump, 4" straight piped, Running on 255-85-16 bf mudders. Full autometer gauges. KDP killed!
1996 2500 cummins. Slightly built auto, autometer gauges, fuel plate, 295-70-17 toyos mt's, custom built headache rack.
www.RallyontheRocks.com
doznfire is offline   Reply With Quote
Old 01-15-2009, 08:17 PM   #5
DU.DP.
DU.DP.'s Avatar
same problem here! i think im in the right chapter im from the salinas area all there are is the southern and northern and it sounds like central coast one is stretched out quite a distance? any help please
thanks david
__________________
93 w250 LE. 4x4 auto. 3:54 gears. 246k miles, power screw turned in a little past factory stop, throttle linkage moved, borgeson steering shaft, tinted windows, 4in downpipe! waiting on more pipe to finish, and white faceplate guages with blue LED's oh and lots of LED's all over my truck.
DU.DP. is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
