Thread Tools | Search this Thread | Display Modes |
#1 | ||
AirDog 150??
__________________
'6.5 RCLB 1ton, 6-Spd, Level kit w/Arnott Air bags, XD HOSS, Toyo OpenCountry A/T 325/60/18D, 62/71/13ss^S480 Twins, SBC 3600 DD Solid hub, 62" Traction Bars, AD150, 5x10's II, SMARTY TNT-R PoD, MP-8, Hamiltons Springs and Pushrods, ARP's, Floor It Diesels new Stage3, 5" TB, 5 Optix guages.. 494hp 932tq at Hi-Tech Oct '9 1.82 60' and 8.27@89 1/8th 700 club 4-27-08, 721 miles 37.69g SAC member #298 DTR "Twins" Club Member #54 |
#2 |
I'm not 100% sure here, I have been researching the AD and FASS for some time now. Anyway if I remember right the FASS runs Fleetguard filters so best of both worlds. Anyway you can go to a parts store I.E. Napa and they can cross reference fleet guard numbers and also do a size comparison and find you an equivalent filter. A little hint too, Napa filters are good they are made by Wix and when you get that big in filters they are really reliable because they get used on Heavy duty diesels, Most likely a water seperator filter too.
__________________
Clint 04 Gunmetal QCSB 4x4 2500 5.9L. NV5600, Van Aaken C3.2, Predator stage 2. Stock intake, stock exhaust, muffler delete, glowshift boost, pyro, and fuel pressure, Nitto terra grappler 285/70/17's on H2's. |
#3 |
Okay so I don't know if they are the same as the AD but Fass uses Fleetguard HF 6604 for the fuel filter and and FS1023 for the water seperator on their system hope that helped, have the guys at the parts store check your filters and see if these two parts numbers come up for your filters, if so Fleetguard and Napa filters are both good filters. Hopefully you know what I am talking about here and hope some of it helped.
#4 |
Fleetguard numbers for the filters are:
Airdog Fuel Filter: FF5613 (3 micron) Airdog Fuel Filter: FF5617 (7 micron) Airdog Water Separator: FS19768
__________________
Member #33 - DTR MegaCab Club Join Here Another Version-AD150 Canister Mod / MegaCab Install 2007 Khaki Dodge 3500 SLT MegaCab SRW 4x4 5.9L CTD 6-speed handshaker, SBC dual disc, smoked cablights, front & rear Timbrens, Pacbrake PRXB, Bilstein 5100's, DSS, lost kitty & demufflerized, Scotty V, aluminum front bumper, remote controlled aux. lighting, Commander, Smarty POD, AD150, 2" leveling kit, Espar, P3, 80% debadged, Amsoil everything, & some bling. |
#5 |
thanks for the help guys!!
#6 |
so i called the local napa, and i was told the part numbers dont cross over..? i also went to http://www.fleetguardfilters.com/store/merchant.mv? and entered the numbers there. no matches also. any ideas or cross ref numbers?
#7 |
napa/napa gold filters are made by wix. wix shows on their website that it is a good number but they do not offer a filter for that number. I think the fleetguard site has a problem because if you search cummins filtration site, it comes up as an offered filter
__________________
04.5 QC, 3.73, 2wd, 6 speed S&B intake w/ Amsoil dry cone filter 5" chrome turndown Airdog 100 |
#8 |
Micron rating/Air Dog/Fleetgaurd
10/FF100-10/FF5617 3/FF100-3/FF5613 W/S WS100/FS19768
__________________
-2004 QC/LB, 4WD, 305/555 CTD -Fabtech 4.5"/37x12.50/H2s -MBRP 5" Turbo-Back Exhaust -GDP Air Boss, GDP Power-Flo, GDP Grid Delete -Air Dog 150, ARP Studs -IceBox Intake w/ DPP Cool Hose -Quadzilla Commander / Quad RPG -SMARTY SR POD -ATS Pulse Flow, BD SPECIAL 64/71/14 -T&C WILD Fuel Rail, T&C 26K CPRV -II Dragon Fire 85% CP3 -II 100HP Nozzles -Custom Built 48RE Trans |
#9 |
Wow that's crazy I used to work at napa and I could cross reference Fleetguards all day I had a huge huge book for it biggest one on the rack, anyway I was just giving an example with the fass filters. Like I said I don't know too much about the air dog so they could very well be completely different filters. I feel kind of bad stumbling in blind to help, just thought of an idea that could help you find an equivalent filter, sorry for the confusion but hope it helped some.
#10 |
thanks Bowser. I called the light duty cummins shop, and they (fleetguard filters) will be here tomorrow.
-dru |
| Display Modes | |
