#1 |
Aftermarket Cruise Control With Factory Controls
After spending a couple weeks trying to get my cruise control working, I gave up. I really would wanna get it working but it would be cheaper I think to put an aftermarket kit of it. I was browsing online and in some Smart forum and someone said he had an Audiovox kit which he used his factory controls. All the part I have work except something in the wiring wont let it work. Does anyone have any help about this topic?
__________________
2001 Quab Cab Shortbed 2wd, 8800 GVW, AD100, Edge w/ Juice, Straight Exhaust (Mostly 5 Inch), New VP44, BHAF, 3rd Gen Rims and 2 Inch Lowering Shackles |
#2 |
might be your PCM/ECM is bad it controls the switches and cruise
__________________
1990 W250 bought new in Nov. 89 performance built 727 and torque converter , high miler 700 k heavly bombed kelderman air ride 2001 2500 HO 6spd 4x4, Engine brake , mad.ecm mach1.6s fass,SBC 4" turbo back exhaust BHAF fluid damper,ARP head studs, DSS, Fast cools.snow w/m, wife says trucks fast enough:( 335 hp/800 tq) How many of your rights are you willing to give up before you feel totally safe ?Wake Up People vote EVERYONE OF THE BUMS OUT OF OFFICE! |
#3 |
well I've tired two different ECMS but I say its not worth trying to get fixed
#4 |
Have you tried replacing your brake light sw? They are a known problem, 3 sets of contacts, 2 of them for the cruise. For many years Chrysler cruise or ARA cruise was generally regarded as the best and most reliable out there. I would just fix what you have as it will most likely be something simple.
__________________
2001 2500 quad 4X4 5 spd Stock except gauges |
#5 |
Well I'm not getting power out of the servo, brake switch, the signal wire from the ECM or PCM. I have a short in my done light wiring in the past and also one of the 12 volt inputs to my ECM I had to fix because it wasn't getting power. I could try jumpers and what not to see if I could get it working but I don't wanna short anything out.
#6 |
For the cruise to turn on, the brake sw must have power through the normally closed contacts. The open contacts are for the brake lights. If you have power to the brake light sw on the normally closed contacts but non out the other side your brake light sw is a problem. One set of contacts returns power to the PCM to indicate the brakes are not applied the other set supplies the cruise servo.
#7 |
There is no power at the brake switch so I got a new one and the cruise didnt work. If I don't get my lower shackles tomorrow, I will work on it again. Do you know where the power comes from to the brake switch?
#8 |
well I seemed to not of installed the brake switch right so I'll check the cruise tomorrow since I read the instructions
#9 |
Power is supplied from the PCM to both normally closed contacts of the brake sw. One set returns power back to the PCM the other set goes to the cruise servo.
#10 |
I have tried a PCM from a late 2001 and my factory one, i haven't tested for power at the switch since I put my factory computer back in. I thought i read on here that someone with a later 2001 didnt need the servo so maybe they did away with that starting that year.
#11 |
Diesel With Manual Trans.
The speed control system is fully electronically controlled by the Engine Control Module (ECM). A cable and a vacuum controlled servo are not used if the vehicle is equipped with a manual transmission and a diesel engine. This is a servo- less system. The controls consist of two steering wheel mounted switches. The switches are labeled: ON/OFF, RES/ACCEL, SET, COAST, and CANCEL. The system is designed to operate at speeds above 30 mph (50 km/h). WARNING: THE USE OF SPEED CONTROL IS NOT RECOMMENDED WHEN DRIVING CONDITIONS DO NOT PERMIT MAINTAINING A CONSTANT SPEED, SUCH AS IN HEAVY TRAFFIC OR ON ROADS THAT ARE WINDING, ICY, SNOW COVERED, OR SLIPPERY. DESCRIPTION - VEHICLE SPEED INPUT Gas Engines and/or Diesel With Automatic Trans. The Vehicle Speed Sensor (VSS) is no longer used for any Dodge Truck. Vehicle speed and distance covered are measured by the Rear Wheel Speed Sensor. The sensor is mounted to the rear axle. A signal is sent from this sensor to the Controller Antilock Brake (CAB) computer. A signal is then sent from the CAB to the Powertrain Control Module (PCM) to determine vehicle speed and distance covered. The PCM will then determine strategies for speed control system operation. Diesel With Manual Trans. The Vehicle Speed Sensor (VSS) is no longer used for any Dodge Truck. Vehicle speed and distance covered are measured by the Rear Wheel Speed Sensor. The sensor is mounted to the rear axle. A signal is sent from this sensor to the Controller Antilock Brake (CAB) computer. A signal is then sent from the CAB to the Engine Control Module (ECM) to determine vehicle speed and distance covered. The ECM will then determine strategies for speed control system operation Diesel Engine With Manual Trans. Vacuum is not used for any part of the speed control system if equipped with a diesel engine and a manual transmission. Diesel Engines With Automatic Trans. On diesel powered engines equipped with an automatic transmission: an engine driven vacuum pump, a one-way check valve and vacuum lines are used to supply vacuum to the speed control servo. A vacuum reservoir is not used. This is out of the 2001 manual. Apparently a big change was made along the line. I have the servo system and have my own CC problem. I am, finally, going to do another CC test this afternoon. It may be the last one too.
__________________
1996 Ram 2500 SLT Ext Cab, CTD, 2x4, 5 Spd, Longbed, 3.54 LSD, KDP Tab, K&N Air Filter, Basically, a stock farm truck, 264,500 Miles. |
#12 |
I have factory 2000 and 2001 manuals, they are both the same and say that a servo is used. However I also remember someone on here saying they installed cruise and they didn't need the servo. It is probably the later 2001 or even the 2001.5 that didn't get the servo.
#13 |
Trucks with a manual don't use servo. Trucks with auto do use servo.
If I remember correctly, mechrisme has an auto so he will need the servo.
__________________
2001.5 2500 4WD QC, sb, 5-sp, 3.55 |
#14 |
I was thinking I would just connect all the wires directly instead of using the factory wiring to see if that would work. I have tried two different ECMs, one was out of a later 2001 one though. All the parts are good, its just something wont let them communicate.
| Thread Tools | |
| Display Modes | |
