Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 03-08-2008, 07:45 PM   #1
DISTURBED
DISTURBED's Avatar
Afe
K so I would really like to get and intake system.... I think it'll help out with my chip and for a little mileage....but mainly just to hear the turbo whistle anyway i'm thinkin of either gettin the stage 1 or stage two from AFE (pending on price) so my questions are -
1 - where can i get one for the best price?
2 - should i get the stage 1 or stage 2?
3 - and what is the differnce between the basic afe filter, the dry filter, and the pro gaurd filter?
__________________
TRUCK - 2001 DODGE 24 VALVE CUMMINS HIGH OUTPUT 6 SPEED
SUSPENSION - LEVELED
TIRES - TOYO A/T'S 285/75/16
MOD'S - SILENCER RING M.I.A, BOOST ELBOW, STRAIGHT PIPE'D, FASS HPFP 95, EDGE JUICE WITH ATTITUDE, AFE INTAKE
DISTURBED is offline   Reply With Quote
Old 03-08-2008, 08:11 PM   #2
GrayGoat
try thoroughbreddiesel.com , nice guys , good price. get the stg 2, you will really notice the turbo. my brother has a duramax and is very jealous of the way mine sounds!!!!!
GrayGoat is offline   Reply With Quote
Old 03-08-2008, 08:18 PM   #3
Night Rider
Night Rider's Avatar
I got the Brute force one and I love it. I found mine on the net at e-bay got it for $75 including shipping but it was used (looked brand new though)keep looking and you can find a great deal if you have some time.
__________________
2001.5 Quadcab 3500 4X4 NV4500 5speed
Silencer ring...what that was supposed to be there??
Quad Xzillaraider/Edge Ez stack,Hypertech and +125 injectors
Big line kit(home made) and removed banjo bolts with In-line holley gerotor
AFE brute force intake, 6" stacks
Evil Motor Sports Fuel pressure(actualy use an oil pressure gauge), boost pressure, and EGT guages
Water meth injection stage 2
Maryland DTR Chapter #33
IronWorkers Local #5 Washington D.C.
Night Rider is offline   Reply With Quote
Old 03-09-2008, 11:44 AM   #4
24V-DSL
My turbo sounds like it is in the glove box....
aFe Stage 1, with filter (don't 'uhmember the PN), that has filtering media in the end. Then, drill a 4 1/2 inch hole in the cowl on the firewall. The filter will be a couple of inches from the hole. The cowl is a very large plenum and pushes a lot of air. This is the way the old Scotty systems were installed. To give it a finished look, buy a rubber grommet for the hole from any auto parts store.
The difference in the filters is the number of layers. I think mine is a five layer, and the Proguard 7 is......you guessed it, seven. Not sure about the dry filter. I don't drive in dusty conditions, and with a pre-filter, my filter never gets dirty. Just wash the pre-filter in warm, soapy water and let air dry a couple of times a year.
Call Rip Rook. www.sourceautomotive.biz
24V-DSL is offline   Reply With Quote
Old 03-09-2008, 11:49 AM   #5
DodgeCowboy
DTR's Cow Boss
DodgeCowboy's Avatar
You guys realize that our stock air boxes are good till like 500 rwhp? for what little egt drop and mpg gain you get for the price its not worth it. take the boot out of the stock air box and you essentially have a s&b intake.
__________________
2001.5 2500 24Valve Sport 6spd HO
Diamond Eye 4'' Exhaust,Jake Brake,SouthBend Con OFE, FASS DDRP, Circle D Flat Bed,Quad XZT+,ISSPRO Boost Pyro & Fuel,Edge Boost Elbow
Here's to colic, strangles, and scours, founder, prolapse, and pink eye, greasy grub, poor pay, ridiculous hours—May we be cowboys until we die!
DodgeCowboy is offline   Reply With Quote
Old 03-09-2008, 01:45 PM   #6
carl48
you are going to lose 10% efficiency by adding the afe because of the hot under hood air, need to stay with something that only allows cold air
__________________
06 3500 4X4 dually qc G56 dynatrac free spin fitch fuel catalyst BD exhaust brake donaldson m90535 muffler, cfm+, winspeed heater delete, smarty jr 750 luberfiner bypass filter taylor wings, psm air, cool hose, tag, air tab's, reese 20k 5th wheel, pdr cam,ddp50 hp injectors
carl48 is offline   Reply With Quote
Old 03-09-2008, 03:39 PM   #7
Big Dblue
Big Dblue's Avatar
I got the AFE stg 2 for $350. I thought this was a good price and thats all the money i had. I couldn't afford anything else so i took the plunge. I LOVED it. And yes you will hear the turbo like crazy. With the AFE and Edge i gained about 4 mpg. So i say yes go for it.
Trapper.
__________________
06 Dodge 2500, 4x4, 48re~COLD!!!
Big Dblue is offline   Reply With Quote
Old 03-10-2008, 11:14 PM   #8
DISTURBED
DISTURBED's Avatar
k cool thanks guys
Old 03-11-2008, 06:56 PM   #9
afoulk
Or, if your just worried about being able to hear the turbo, just go with a BHAF. Thats what I have on mine, along with a heat shield I made for it, and the turbo is plenty loud to suit me. I think for the little bit of fuel mileage you would gain from a intake system, this is your best bet. VulcanPerformance.com has the BHAF filters for $38 and some change, cheapest I've seen. Just cut the hole in your cowl as mentioned above, and you'll really be able to hear it.
__________________
02 4x4 2500 H.O./6spd qc/8ftbed, 2" leveling kit, no silencer ring, BHAF w/heatshield, straight piped stock exh., FASS 150, Vulcan DS, DSS, 3rd gen. adj. trackbar, Isspro gauges (fuel,boost,pyro), S.O. VP-44, RV275's, Edge EZ, blocked off w/g
afoulk is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
