Advice on brake bleeding
Old 08-30-2014, 02:32 PM
rrgrassi's Avatar
Originally Posted by NJTman
If this was true, you would have a line of fluid coming out the bottom back side of the master, or being pushed into the brake booster itself. Anytime a master had gone bad with me, It always leaked out the back and down onto the frame.
I have experienced this with GM vehicles without external leaking. Where the seals for the externals did not fail. but the internal ones did. No air in the system, and no dropping fluid level either. Talk about chasing your tail!
Old 08-30-2014, 07:24 PM
Received 1,637 Likes on 1,112 Posts
Well, that explains everything....
I had a 84 vette, and nothing was good on that junker. Everything failed except for the engine. Fuel system, electric, suspension, seals, gaskets, steering..... you name it .... it failed.
That's what you get for owning a piece of american history...
Old 08-31-2014, 02:23 AM
rrgrassi's Avatar
So true. A Wagner M/C fixed that problem on an old Pontiac I had. I will not ever buy a '74 or higher GM car, or a 79 or higher GM truck.
GMC=General Mechanical Crap or Garage Man's Companion
Old 08-31-2014, 08:43 PM
bigragu's Avatar
Update- upon removal of the brake booster the rod end that connects to the pedal falls out with pieces of something torn at the end of the rod. I am wondering when I was pumping the brakes trying to bleed out the air I felt/ heard this pop at the brake pedal and after that I could not hold any pressure at all and that's when I quit. Been following all the bleeding advice on here and the pressure would build up then fade away at start up. Booster fell apart as I exchanged it with another reman from orileys. According to my notes, That one lasted about a year
Old 09-01-2014, 07:29 AM
maybe368's Avatar
I can't imagine what could be at the pedal end, it just connects to the pedal with a clip. I know that most rebuilt boosters, or mc's, (can't remember which ) come with instruction on how to adjust the push rod and that this has been an issue. I still don't see how a bad booster can put air into the brake lines, that is probably the mc...Mark
reidry
08-11-2006 01:19 AM
reidry
08-09-2006 01:42 PM
displacedtexan
02-02-2006 06:42 AM
FRANKV569
01-22-2005 06:55 PM
McGyver
15
12-01-2004 11:15 PM
Quick Reply: Advice on brake bleeding
