Thread Tools | Search this Thread | Display Modes |
#1 | ||
adjusting valves
__________________
1998 CTD, 12V, #10 plate, 16cm2, 3K GSK, ATS exhaust manifold, KDP secured, AFE air filter, 5 speed, US Gear Overdrive, and 4.10 Dana 80 rear. |
#2 |
You always rotate the engine in the same direction that it runs.
__________________
97, 2500,4x4,ec,auto,sport,black,saddle tan int.,3.54 gears,#10plate,3kgsk, afc kit,scotty 2, gutted cat,high flow muffler,oil guard bypass filter,egt, boost,trans. temp.guages |
#3 |
The engine turns CW, the barring gear would be CCW. You are also rotating the engine one full revolution, so direction has no effect on the destination.
__________________
'98 3500 4x2 Quad Cab, 24v, 5 spd, 3.55s, CDS 13mm, SDX 7x.012 Injectors, Single S480, Big Stick Cam, FASS, BD Short Shifter, SBC DD, Fluidampr Alcoa Magnums, GM Brake Cylinders, HID Headlights, DSS '98 2500 4x4 Reg Cab, 12v, 6 spd, 3.55s, 0 plate, 4k GSK, 18° Timing, SBC DD, F1 370's, GT37R/GTX42R Twins, Fluidampr Alcoa H2's, Lorado Tonneau Cover, HID Headlights, Espar D5, EMS Hub Conversion |
#4 |
It doesn't matter which way you turn the engine to TDC of #1 or #6. Once you find it I recommend you mark the damper. One full turn will give you TDC again to chech the other 6 valves.
__________________
97 3500, G56 6 speed, lightly bombed 775+k miles (OVER 3/4 MILLION MILES!!) |
#5 |
Thanks for the help.
#6 |
fwiw you can turn the motor over using the nut on the alternator pulley
__________________
97 12v x-cab 4x4 MARYLAND DTR CHAPTER #33 |
| Display Modes | |
