Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 11-06-2008, 10:04 PM   #1
glocklove
glocklove's Avatar
AD100 or AD150???
Okay some one please shoot me!!! I have been huntin off and on all day about weather I can use a AD150 or do I have to use a AD100. Searched, went back loooong ways in the threads and could not find the answer.
So with what I have can I run the 150 or will I hurt somethin? I would perfer to do this mod once not twice and put another 500 bucks out.
__________________
'06 CTD /CAI/5" TBE 6" Tip/
Smarty pod s-06/AD 150/CFM +/Grid heater Delete/Arson III/HTT ss Exh manifold/Goerend trans/ II 60 hp nozzles/BD SprBspl/Hamilton cam, 110# valve springs, push rods/ ARP hd stds/
glocklove is offline   Reply With Quote
Old 11-06-2008, 10:08 PM   #2
madhat
Administrator/Jarhead
madhat's Avatar
Go with the 150. I have it, and maintain about 20 lbs of pressure at the CP3.
What are you worried about hurting? I think that the only thing different on the instal is that you have to drill the tank to insert the draw straw.... note on that... drill it right infront of the FSU... not behind, or you'll suck air when you hit the brakes...
__________________
04.5 3500 4x4 Tranny, turbo, injectors, studs, springs, CP3 mod, smarty, MP8, Air Dog, 5" TBE, some other things... 868/1778
madhat (at) dieseltruckresource.com
madhat is offline   Reply With Quote
Old 11-06-2008, 10:36 PM   #3
Power Ram 4X4
Power Ram 4X4's Avatar
I put the airdog 100 30psi pump on mine. Really like it and no drawstraw to worry about runs aboud 28-29psi all the time even at wot.
Trent
__________________
2004.5 2500 ctd qc/sb 4x4 nv5600,SMARTY REVO,Air dog 100, 2"revtech leveling kit,35/12.5/17 pro comp xterrains on moto metal 957 black wheels,quadzilla boost fooler,bd short throw shifter,straight piped,k&n fipk intake with amsoil filter,power wagon fender flares, debadged,autometer a pillar gauges boost egt trans,quadzilla rail and fuel pressure gauge,
SAC #176
Power Ram 4X4 is offline   Reply With Quote
Old 11-06-2008, 10:42 PM   #4
rip 112
rip 112's Avatar
If you're staying below 600hp AD100, over 600 Ad150. JMO
__________________
Rick-04 2500 2wd 305/555 nv5600 , Smarty Beta 4.x/ MP-8, HTT 62/71-13ss, Airdog 100, SBC Con OFE, BD Short shifter, Isspros, AFE stg. 2, CFM horn, RSD 5" , LED tails and cabs, 20" Helo Core, 275/55 Terra Grapplers. Memphis Audio, Kicker L5 15.
08 Rhino 700fi 4x4 on 27"s
07 Yamaha Grizzly 700 on 27"s
contempt breeds contamination
Aug 08 TOM
rip 112 is offline   Reply With Quote
Old 11-06-2008, 10:54 PM   #5
98whitelightnin
98whitelightnin's Avatar
We put a raptor 150 on my grandpas truck and all he has is a edge ez and it works great. The 100 will have more pressure but the 150 will flow more fuel per minute. We went with the biggest one the first time with no regrets.
__________________
98 24 valve nv4500 swap 4x4
98whitelightnin is offline   Reply With Quote
Old 11-07-2008, 06:37 AM   #6
Bad-Duvall
Bad-Duvall's Avatar
150 if you like to do things once!
__________________
2007 Dodge Ram 2500, smarty tnt-R, AD 150 fuel system, south bend triple disk 3850, A cam, Springs, Duels cp3s, Fluxed, Fly cut pistons, Snow Stage 3, 2.6 turbo, line board for cam berings, Arp head studs, no cat, no muffler, raceline rengade wheels & 305/75/R17 Mickey Tomson ATZ's[
HOWS THIS FOR SECOND HAND SMOKE?
Bad-Duvall is offline   Reply With Quote
Old 11-07-2008, 06:39 AM   #7
megacabdad
megacabdad's Avatar
Like the quote on here, "the only time you have too much fuel is when you are on fire."
Bigger is better in this circumstance, IMO.
__________________
Alan
06 MEGA
February 2009 TOM
megacabdad is offline   Reply With Quote
Old 11-07-2008, 11:26 AM   #8
AirDog
Guest
I suggest just going ahead and doing the 150. You have to put the suction tube in regardless with having the in tank pump. Its only $10 more and also carries the Lifetime Warranty.
Old 11-07-2008, 03:06 PM   #9
Fisherguy
Fisherguy's Avatar
Quote:
What he said, the 100 is all most of us need.
It also depends how handy you are, my AD100 and modified Liberty canister works well but it takes a little fiddlin with the return line to get around the low fuel issues.
If you go with the 150 you'll end up doing 2 draw straws if you use your stock canister or the Liberty.
__________________
Liberty Canister Mod
Machining H2's
AirLift Wirelss controller install
misc pics
06 3500 QC 6 spd; DiPricol; SMARTY; S&B; Quad X2; AD100/Liberty; OFE; 40" Nelson; PB PRXB, air bags & AirLift wireless controller; Raider cap; 4 KC's on RED; leveled; Bilsteins; 285/75R18 TOYO AT2's on Level 8's; B&D brace & TB, ATS flares, PP CA's.
Fisherguy is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
