Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 06-23-2008, 11:39 AM   #16
cquestad
cquestad's Avatar
What about the downfalls of dumping the hot return fuel right back into the pickup "area"? It soulds like you could have made a great fuel heater? Maybe not...
I am so glad I have an 03-04 style pickup canister.
Whoops...did I read that right...that was the return from the lift pump????
__________________
04 HO: Custom Audio, 4.5" up w/ 2.5 Kings, Thuren Springs, 37" XAT on XD Hoss, Custom headache rack/steps/bumpers, bedliner, flares, SS aux tank, Brite Box, B&W Hitch, Trailer Brake, Turbo Timer, Diprocal's, HTT IC, Opie Bypass.
Ultimate Trans w/ Opie Fat Shafts & ATS Commander
MPI Twins, Flux's, F1 Springs, Helix 2, Evil Twins, Opie's Gusher LP, GDP 2 mic & Intake, ARP 625's w/ Orings, Smarty, TST, MP-8...
DTR "Twins" Club Member #3
cquestad is offline   Reply With Quote
Old 06-23-2008, 11:49 AM   #17
53 willys
53 willys's Avatar
I dont think there is any downfall to having the the return line going back to the canister..engine or lift pump..the engine return goes back there no matter what anyway...lift pump just keeps the canister full..the airdog return fuel is far from "hot"
__________________
Sorry guys the Willys Wistler Intake is DIY intake...I'm not making and selling them.
thanks
53 willys is offline   Reply With Quote
Old 06-23-2008, 12:19 PM   #18
Fisherguy
Fisherguy's Avatar
Right Mark, and even if it is slightly warm it's still better than, having the canister running dry which is what it was doing before the mod.
When I was tinkering with this I was playing with the setup in a 5 gallon pail, the fuel from the AD was not "hot" at all.
__________________
Liberty Canister Mod
Machining H2's
AirLift Wirelss controller install
misc pics
06 3500 QC 6 spd; DiPricol; BDTD/CL; S&B; Quad X2; AD100/Liberty; OFE; 40" Nelson; PB PRXB, air bags & AirLift wireless controller; Raider cap; 4 KC's on RED; leveled; Bilsteins; 35" E rated Vortracs, chrome H2's; B&D steering brace, ATS flares
497 HP, B&D Dyno Days, Oct 09
BDAC MEMBER #1
Fisherguy is offline   Reply With Quote
Old 06-25-2008, 08:52 PM   #19
WILDBILL01
ha Fisherguy thankes for clearing that up for me. I have a 100gph AD one the way. I would just as soon do it right the first time and not have any suction problumes at lowe fuel levels like so many have. But thankes for tutering im newbe but tring to learn.
__________________
2006 5.9L 2500 Quadcab 4+4, Rinoliner,5" Silverline TurboBack, QuadZilla Gauges,AirDog 100, Frantz ByPass Oil Filter, K&N Big Dropin Filter, Intake Silenser MIA,Smarty POD,2'' Level Kit,4 Bilstines,PML Front&Rear Dif Covers, Cheap Vent Kit,
WILDBILL01 is offline   Reply With Quote
Old 06-25-2008, 11:34 PM   #20
Fisherguy
Fisherguy's Avatar
No problem, glad to help, Mark has been a real inspiration!
Old 06-26-2008, 02:44 PM   #21
zuki_dan
zuki_dan's Avatar
I have done about the same thing. But instead of using the drawstraw as a return, it is the pick-up for my fass. I'm using the old factory feed line as a fass return, I bought the dorman fitting to 3/8 line adapter from glacier. And I also have my factory return filling the bowl as well. I don't have fuel pressure problems until the tank is empty. I even drove it til it was on E and drove around agressively to try and get it to suck air but fuel pressure was steady.
__________________
'06 2500 MC;TRE Trans, Twins Turbos, Dual Fuelers, ARP's, O-Ringed, Fluxes, Springs, Helix, Fluidampr, Bladerunner, Fass, Stacks, Smarty, TST, Dr. P, Snow, Optix Gauges, Bypass, 35 XAT's, Lorenz leveled.
1/4mile 12.13 @ 118.4mph 2-21-09
zuki_dan is offline   Reply With Quote
Old 06-26-2008, 07:13 PM   #22
Fisherguy
Fisherguy's Avatar
Cool, did you use the factory canister with the pump removed or a Liberty unit?
Old 06-26-2008, 07:20 PM   #23
rufushusky
Wow that is great! Nice work and great pics!
__________________
2004.5 Reg Cab 4x4 w/ 5.9 Cummins Smarty/TS Ramifier, AEM intake, Banks High Ram, Autometer Boost, Pyro and trans on the pillar Fass HPFP, Isspro Fuel pressure gauge, Optix Rail Pressure gauge, 5" exhaust, Caterpillar Fuel filter, Amsoil bypass
rufushusky is offline   Reply With Quote
Old 06-26-2008, 08:11 PM   #24
zuki_dan
zuki_dan's Avatar
Quote:
I used the liberty module.
Old 08-02-2008, 06:48 AM   #25
Hvytrkmech
DTR's "Puttin fires out and workin on big trucks" member...
Hvytrkmech's Avatar
Very nice job on the fab up and install Fisherguy. I do have one question though. Since the A/D removes the air from the fuel then returns the air raided fuel to the tank via the return line, and with the return line routed to the same location as the pick up, isn't this making the A/D set up work harder, and defeating the intended purpose? Seems like a cascading effect of drawing air raided fuel.
I understand why you guy's did this mod was to eliminate low fuel issue's, but did it create another problem?
This is just a question guy's, not insulting anyone. All of you did a super nice job fabing up and solving the low fuel issue's.
Tim
__________________
Tim
2006, 3500 QC/SRW/LB/48RE/4.10/Inferno red, Mag-Hytec trans and diff cover, Isspro gauges, Quad XZTII, GDP 2 micron kit, Air Dog 100, install with pics- http://www.dieseltruckresource.com/d...d.php?t=185809
Hvytrkmech is offline   Reply With Quote
Old 08-02-2008, 09:05 AM   #26
53 willys
53 willys's Avatar
Tim
the AD can separate 80% air and still be effective...plus the bubbles will float to the top of the canister while you are sucking up fuel from the bottom of the canister...I dont think it's a problem....
Old 08-02-2008, 11:19 AM   #27
Fisherguy
Fisherguy's Avatar
No offense taken.
Like Mark said above (and he was a big help with my project), not really an issue. Most of the time the canister will be submerged in fuel anyhow, it's not very often I run the tank to ¼ tank or lower anyhow, especially when filling the thing up costs me about $200 cdn!
Old 08-03-2008, 06:54 PM   #28
Hvytrkmech
Hvytrkmech's Avatar
Cool, thanks guy's.
Tim
Old 03-30-2009, 04:08 AM   #29
ctd4stan
Fisherguy,
When you did the canister mod, did you put the return line almost to the bottom too (like the suction line)?
__________________
Thx, Stan
2004 Dodge Ram 2500 Laramie, QC, SB, 2WD, SO 235/460, 48RE AT, 3.73, Deep Molten Red / Silver, SilverStar 9007s, AirDog II
ctd4stan is offline   Reply With Quote
Old 03-30-2009, 07:19 AM   #30
Fisherguy
Fisherguy's Avatar
No, I put the return just below the plastic supports when it was sitting on the bench. I just wanted to put so I new it would pump back into the canister. I guess I coulda shortened it a little and uses a tie-wrap to hold it in place against the spring in the picture below.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
