Thread Tools | Search this Thread | Display Modes |
#1 | ||
AC Question- AC works fine in town but not on Highway???
__________________
1997 Ram 2500 SLT Larime 4x4 330k and counting; first motor, third transmission. Straight Piped, 3k GSK, Scotty II, Gauges, DTT valvebody |
#2 |
Blend door maybe?
__________________
JESUS SAVES! 1998 Dodge Ram 2500 QCSB 12v 5-Speed 4x4 3.54 gears - SDX 5x.012, S300G Turbo, Custom Fuel Plate, pull cable shut down, 4" straight pipe, GM 1 ton wheel cylinders, other stuff... sold...2006 Dodge Ram 3500 4x4 6-Speed QCLB / 1997 Dodge Ram 2500 4x4 Auto CCLB / 1993 Dodge Ram W250 4x4 Auto CCLB / 2002 Dodge Ram 2500 4x4 6-Speed QCLB Founder INDTR #29 |
#3 |
Have you check AC pressure? Low coolant? One test I do Is short the control plug at the condensor near the fire wall to see if compressore is running right.
#4 | |
Quote:
When it is setting idling and the AC on, does the clutch cycle at all?
__________________
"Brownie" 1997 2500 Ext.cab SLT, 4X4 auto, 3.54 gears, posilock, 98/99 steering conversion. New TC, lovin her again! Sold 3/13/2010, gone but not forgotten. "Greenie" 1997 2500 Ext. cab SLT, 4X4, NV4500, 3.54 gears, 4" MBRP Exhaust, Ready to install SB DD3250, built just 216 trucks after Brownie! |
#5 |
I can sit in my driveway idling all day long and AC is ice cold. If I drive down the highway at speeds above 55-65 or so AC blows luke warm
#6 |
Probably blend door. Check vacuum on the mixer and see if it is adding warm air under slight load.
__________________
03 Thor Tahoe 20 TB Transporter 91 Dodge CTD W250 Power Ram - SOLD 97 Dodge CTD 2500 4x4 Club Cab LWB w/#8 TST, boost elbow, gauges, Goerends triple disk TC, Goerends VB, and billet shift lever, Magnaflow 4 "exhaust |
#7 | |
Quote:
I would get a set of gauges on it first. |
#8 |
Let it warm up; set the parking brake, tranny in neutral or park; then have a friend rev it up to 2400 rpm and see what it does. The compressor clutch may be slipping at high rpm, you can clean it with some electric contact cleaner which is plastic safe and no residue if you see any kind of comtamination on the compressor clutch hub. It's one thing to get the compressor spinning at idle compared to high rpm. Just a thought but it really sounds like you need to dump some more refrigerant in the system.
__________________
97, club cab, 5 spd, 4x4, 330k, tigged 5th@100k 96, auto, 4x4, 390k 98 grail ;) 4x4, 190k..all stock except 98, fun truck |
| Display Modes | |
