Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 2nd Gen. Dodge Ram - No Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 12-27-2005, 10:44 PM   #1
FORDNOMORE
FORDNOMORE's Avatar
Abs?
Hello, I noticed that the ABS light does not come on when I start my truck. is this normal for a dually? the brakes seem to work fine just no ABS. I checked the fuse for the ABS and it was good so where should I look? I should mention that I have owned the truck for only a few months and that the previous owner took great records of everything done to the vehicle.
__________________
1997, 3500, 4x4, 5-speed, Extendedcab, 4.10, BHAF, 260K and still pull'n, RanchHand front bumper, Nothing Beats the BIG RIG Sound!! OH YEAH!
FORDNOMORE is offline   Reply With Quote
Old 12-28-2005, 12:40 AM   #2
newriverSpecon
newriverSpecon's Avatar
Probably a bulb. It should come on when there is an issue. Not stay off.
Randy
__________________
'99 2500 4x2 5 speed 3.54 OPEN 235/85R16 Michelin LTX M/S, 174,000 miles, Topper, Autometer Ultra-lite Boost, Pyro, BHAF w/insulated box, muffler gone. Van Aaken, Holley Black, custom -8 lines and filter (factory mess gone),13" Con FE, BB pilot bearing, Red Tops, Trans Filter
'97 2500 4X4 5 speed original clutch (it will slip, Con O in work), 3.54LSD,135,000 miles, QC LWB, Banks Power Pack, Maxxis Mudders 315/75R16, Thuren track bar, KDP MIA, Timing @ 16.5, 5th gear gone for now.
newriverSpecon is offline   Reply With Quote
Old 12-28-2005, 10:07 AM   #3
ccmckee
ccmckee's Avatar
Yeah probably just the bulb burnt out, cause it shouldcome along with the other lites for the lamp check sequence at start up.
__________________
'03 QC 4wd 6spd, TST controler w/monitor, silencer ring MIA,100% AMSOIL
gone but not forgotten
'96 2500SLT CC LB 2WD, KDP tabbed,100Hp Maxsticks,16* ,3k gsk,afc modded,#8 tst plate,62/70/13 turbo,4" MBRP exhaust,AFE stage III dry filter intake,autometer boost pyro, oil, tran temp,DSS,rebuilt diff & tranny w/billet triple lock TC w/lockup switch,1tn rear cylinders,ride rites on all 4 corners w/on board air,465k km. 330 hp 766 ft/lbs
ccmckee is offline   Reply With Quote
Old 12-28-2005, 10:24 PM   #4
FORDNOMORE
FORDNOMORE's Avatar
Yeah, probably be my luck that the bulb burned out because it was on all the time. I will look at the sensor and try and do a little more trouble shooting. I will let you all know what I find out. Please keep the Ideas rolling in.
Old 12-29-2005, 08:30 AM   #5
Mopar1973man
Mopar1973man's Avatar
Every time you turn you key to ON its basically a 2-3 second bulb test for the console.
On 2000 and up you can hold the TRIP button down and turn the ignition key to ON the release the TRIP button. This will start a diagnostic of the console. Odometer test, bulb test, and guage test.
So if the bulb isn't lighting up then it burnt out! Time to chnage the bulb...
You can also check the fuses (under the hood and in the cab)
__________________
2002 Dodge Cummins - Way too many mod to list.
Mopar1973man is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
