Main Page Classifieds Tech Facts Member Photos Articles Links Forums Chat
Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 1st Gen. Ram - All Topics
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-02-2009, 10:37 PM
jimbo486's Avatar
jimbo486 jimbo486 is offline
'92 turn signal switch
well i need a new switch as mine doesn't function like it should. very quick and probably easy question regarding it... is the wiring in my '90 similar to the '92 wiring? mine has the integrated high beam switch with the wiper controls also. TIA fellers!
__________________
"my name is jim, but most people call me.... jim"
- blazing saddles -
- '90 D350 LE Cab & Chassis -
159" WB - Custom 9' bed - Fuel pin turned - 1/2 Turn On Starwheel - 4x.014's - Piston LP - Banks Intercooler - 4" Turbo Back, Sans Muffler - 500K+ Miles (ODO Stuck @ 258K) - NV5600 - D70 3.54 LSD - Autometer Tach - VDO Boost - Autometer UltraLite II Pyro
Wish List: GDS 60mm, 3" Cooler Tubes, M3 Fuel Pin
Old 11-03-2009, 03:06 PM
jimbo486's Avatar
nobody?
__________________
- blazing saddles -
Old 11-03-2009, 04:59 PM
92roughstock 92roughstock is offline
If they look the same, try it. But, I think they are different- you probably have to get a new assembly. What is the switch doing/not doing in the 92? The W350 I just sold didnt cancel itself after a turn, but the wipers and hi/low beams worked, so I didnt care.
__________________
1993 W250 xcab, built auto, near stock engine. Gauges and upgrades coming soon
I'll keep my money, my liberty, and my guns. You can have the change.
Old 11-03-2009, 05:37 PM
jimbo486's Avatar
the switch in my '90 is the one that's "bad". it works, but in order for the right-hand turn flasher to work, i have to push upward on it kinda hard. if i don't hold it, i can hear the flasher clicking, but the indicator in the gauge cluster and the turn signal don't flash until i push up hard enough to make contact. obviously it's just getting old and not functioning like it used to. all other functions work just fine. high/low beam switching, wiper functions and it would cancel after a turn also. i just like for my stuff to work like it's supposed/made to. the only reason i ask about the '92 working in my '90 is because i could get it for $30 shipped in these classifieds. or i pay $40 shipped for one from another '90 model elsewhere. if the '92 is a simple "plug and play", i'd know which one i'm buying.
__________________
- blazing saddles -
Old 11-03-2009, 06:30 PM
wannadiesel wannadiesel is offline
How can I best help you today?
They are different.
__________________
Dave
wannadiesel@dieseltruckresource.com
'93 D350 - DPS 6x16's, HTT Stage IV/14wg, PowerStroke IC, Snow water/meth, Walbro 392, Con-FE, pump tampering by owner.
386 HP/774 TQ on #2 only, 408 HP/844 TQ w/ water/meth - needs more air!
"Butterscotch" - '82 Mercedes 300TD
KDP body count: 72
Old 11-03-2009, 06:33 PM
jimbo486's Avatar
thank you dave! i had a feeling and was hoping you'd be the one to give me a straight answer being the guru that you are. that's all i needed to know. going with the $40 one from another '90.
__________________
- blazing saddles -
Old 11-03-2009, 07:38 PM
Old-stuff's Avatar
Old-stuff Old-stuff is offline
signal sw
I just checked at a parts store for a signal sw for my 90/ w tilt wheel.
Thay said that 88 to 90 had the same switch. Then it changed after that. (again, tilt wheel). Mine had a broken base on the outer housing for the signal switch. I made a new stalk from steel. $155 for new switch.
Ray
__________________
95 3/4ton CTD, 5 speed,2wd, modified fuel plate,
3000 gsk, 343000 miles.
91 3/4ton CTD,5 speed,2wd,2turns smoke screw.Vandalized,all Glass and lights broken out.
future base for 47 Dodge PU body.
90 3/4ton CTD, 727,4x4, 4" exhaust, 2 turns full power screw, 3200 gsk.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
