91 1/2 fuel gauge.
Old 10-15-2014, 04:12 PM
Flyingstick15x's Avatar
91 1/2 fuel gauge.
I am having a couple issues with my '91 12 valve. The fuel gauge on the dash reads empty all the time however the low fuel light does come on when the tank starts getting low. Would this be the sendor in the tank or another issue? There is also a sensor on one of the return lines for the transmission cooler on the drivers side right above the transmission oil pan. The sensor is in the line and the wires run up and into the wiring harness. Does anyone have an idea what that sensor is for?
Old 10-15-2014, 07:42 PM
sooty's Avatar
if you can ground the dark blue/yellow stripe wire (sender wire from tank to gauge)either behind the cluster, or somewhere before the tank, gauge should go to full with ign on. if it does, gauge good sender bad, what color is the trans wire you question?
Old 10-15-2014, 09:38 PM
dodgenstein's Avatar
Trans sensor is for high temp (somewhere around Three Mile Island hot) OD cut out. ( I think it is around 280 degrees)
Old 10-16-2014, 01:08 AM
Ok i will trace that wire and see what the deal is. As of now the needle never moves from empty at any point, even with the ign on. The weird part is that the low fuel light still come on when low. On the sensor one wire is orange and one is red. Both are very small gauge. Would make sense it being the OD cutoff
Old 10-16-2014, 08:54 AM
sooty's Avatar
the low fuel light is a separate circuit.
Old 10-16-2014, 02:40 PM
Ohhh ok i was under the impression they worked off the same circuit
Old 10-16-2014, 06:51 PM
Any chance it could b the gauge itself? Ive already got the cluster pulled apart at the moment
Old 10-16-2014, 07:31 PM
sooty's Avatar
yes, but leave it hooked up and do the test I posted previously
Old 10-17-2014, 01:01 AM
Ok will do. Thanks for the help sooty
Old 11-08-2014, 01:48 AM
Thanks for the help sooty. There was a wiring problem with the exact one you told me to check. Works great now
Old 11-08-2014, 08:48 AM
Redtruck-VA's Avatar
Great information, well done..
nrussell
07-23-2008 08:58 PM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
Quick Reply: 91 1/2 fuel gauge.
