6mm plunger lift
Old Mar 9, 2008 | 02:48 PM
aksparkey01's Avatar
6mm plunger lift
Is 6mm plunger lift in a 215 pump about 18 deg timing. the chart i have only goes to 16*, but i following the pattern it should be somewhere in there right?
Old Mar 9, 2008 | 06:39 PM
dieselman2300's Avatar
Yes. This is what I figured also for my 215 pump.
Old Mar 9, 2008 | 09:46 PM
my truck seems to love that timing. man what a difference it is from the 15* it was while i was breaking in the new head gasket.
Old Mar 10, 2008 | 06:06 PM
afoulk's Avatar
What kinda timing would you recommend for a 12v with 60hp injectors, stock turbo, headgasket, and head bolts? My boss has a 98 and tows a travel trailer during the summer. Total weight is a little over 17,000lbs. He wants my buddy to adjust his timing, and we were wondering how far to go with it. Hes also got a fuel plate, but I'm not sure which one. Hes got a built Georend auto in it.
Also, isn't there a formula you can use to figure out how to mark the crank dampner so you know how far 1* is?
Old Mar 10, 2008 | 06:40 PM
logskidder's Avatar
Do 16* and install a GSK
Old Mar 10, 2008 | 06:42 PM
logskidder's Avatar
And you need a timing set....snapon has them for about $250
Old Mar 10, 2008 | 07:08 PM
yep do 15.5 or 16 and a gsk. also do a search on the drop valve method, thats probally going to be the best way to find tdc. you can use the timing pin to get close.
dillenger1
Aug 5, 2010 09:38 AM
Chrisf
Oct 10, 2007 06:53 PM
kd460
Jul 20, 2007 11:10 AM
satburn
Competition / Pulls / OffRoad
Oct 15, 2006 10:36 PM
greasy
Dec 16, 2004 02:52 PM
