#1 |
6.7 Rods???garbage?
are the 6.7 rods different from the 5.9's? and where do they differ?
i have talked to a few people this week, and its only tues, and 3 guys with 07's have had to replace the motors on their truck due to broken Rods. i stop into a tranny shop local to me cause the guy was having a problem with the bully dog not coming off his computer, he said he buddy out west has a new 6.7 and broke the rods in it twice now. i just got back from the scrap steel place and the guy there running the swing shovel wanted to buy my truck cause he replaced his motor once and now is sitting in his drive way broken again. Rods again. no warranty. i am wondering what the difference are between the old trucks and the newer 6.7's
__________________
03 ,quad cab,4x4,black,305HP/555lbs,laramie,48RE,.BURNT new: 04 3500,suncoast,sp62,toyo 35" MT,weld,banks exhaust,afe,air bags,edge juice,EZ,smarty,autometer, |
#2 |
Not the rods so much as the stroke. Longer stroke puts more stress on the rods as RPMs go up, more rotating mass. I haven't actually heard much about it for stock trucks, but aftermarket loaders like the Bully seem to cause more of these failures.
__________________
97 2500 4X4 LWB CC SLT Laramie 5spd LSD 3.55. Isspro EV's pyro/boost, #10 Plate, PEAK 3K GSK, AFC Spring, DDP III injectors, S300 Turbo, PEAK IC Boots, TAG III, South Bend 13-1.25" Con FE clutch, SCOTTY II-UNI, MBRP XP 4", KDP Tab, 16° Timing, SS DSS / 03TBK, Roda Deaco PAS. Espar D5WSC heater. B-Quiet sound deadening inside. Dyno 09-2009 401 RWHP / 1050 Ft-lbs '08 2500 4x4 MegaCab Laramie, 6.7, 68RFE, 3.73 LSD, S-67ME POD. Alberta Chapter #5 Prez... PM me for details... |
#3 |
i think only one guy was all stock, most of those guys were running some sort of power adder
#4 |
So basically stock to mild power mods should be ok??? Anytime you aggressively mod a truck something could happen.
#5 |
i disagree, cause this one guy had an 04 with 3 stacked boxes, and drove it hard, this new truck has one programmer, and it has broken twice now.
#6 |
talked to another guy with 6.7 , 2 broken Rods.
it seems like alot of money to spend, on a truck that can't seem to do anything but pull a trailer, or work hard, but not too hard, and with no programming, and CAN'T go to the stopre, or to the movie, or out to eat in fear of the emmisions stuff going south. can't run any type of diesel,or oil, etc etc. man what happen to the good old days, the 12 valve stuff, dump what ever you like in your fuel, it will burn it, idle all day, it don't care, drive it, pull super heavy, those trucks just didn't care.these new ones, i don't know. i think i will park my 04, and save it for the future. |
#7 |
The EPA happened.. that's what. The old saying "you wanna play, be prepared to pay" still applies today as it always has. As for going to the movies/grocery getting or whatever else, you CAN do these things with the 6.7L. There are a few things a person should do when using it this way however. ALWAYS use tow/haul mode and the EB when driving in town, loaded or not. Keeping the revs up reduces the soot produced. With the newest flashes installed, the 6.7L can be used any way the driver wants to use it. Great strides have been made since the first one rolled off the line.
__________________
2007 6.7 CTD Laramie Quad Cab - Long Box, Inferno Red, Auto - 68RE, Armaguard spray in bedliner, UConnect Bluetooth |
#8 |
I had a 5.9 and now a 6.7.....I wouldn't go back.
__________________
2008 3500 CTD Quad Cab LB SRW 6 speed Auto 4X4 3:73 P3 Brake Control White Born 09/07. |
#9 |
You sure seem to know a lot of guys with broken rods..........
Funny, with you knowing that many, we haven't heard of a single issue here. Anybody over on TDR or CompDiesel hearing about broken rods?
__________________
"Brownie" 1997 2500 Ext.cab SLT, 4X4 auto, 3.54 gears, posilock, 98/99 steering conversion. New TC, lovin her again! Sold 3/13/2010, gone but not forgotten. "Greenie" 1997 2500 Ext. cab SLT, 4X4, NV4500, 3.54 gears, Ready to install SB DD3250, built just 216 trucks after Brownie! |
#10 |
I have been on the TDR many times and haven't read anything of the sort. Now Morkable broke a rod in his 5.9, but he was running about 1200hp on nitrous on the 1/4 mile..
| Thread Tools | |
| Display Modes | |
