Thread Tools | Search this Thread | Display Modes |
#1 | ||
6.7 holsett turbo
__________________
89 w250 250,000, A727, asa intake, fuel screw 1 turn before runaway, fuel pin deepest setting, 3200 spring, 5" tip, rattle can paint, glowshift boost and pyro, timing bump, 60mm gds upgrade |
#2 |
electronic variable gemetry. :nono:
__________________
91.5 W250 4x4 5 speed LE Red/Grey, 270k miles, 3.54's w/ Power-Lok, 4" Exhaust, BHAF, DennyT Pin, 3200 Spring, Piston LP, Power screw maxed, HX35/12cm, DAP 5x14 Injectors, Valair 13" 550hp K/C clutch, 4" Skyjacker soft-ride lift, 315/75R16 Mickey Thompson Baja ATZ tires, 16-17 MPG 89 D150 3.9L TBI/A999 Auto, beater while ^^^ gets restored Attending LTI for Diesel Truck Technology, graduate December 2013 |
#3 |
what that mean?
#4 |
Best Paint (Getrag category)
Does anyone know if someone makes a stand alone controller for a VGT turbo yet
__________________
90 W250 reg cab, Modified knuder valve, reversed reciprocting dinglearm adjusted, High volume flux capacitor,upgraded whirlygig, A clutch and a hitch 428,500 miles 307hp 672tq uncorrected 4-25-10 July 2008 TOM 93 W350 ext cab dually 5spd Stock 401,000 miles The old mans ride. 91d350 n/ic, 366, getrag,D80 stock afc cone set deep,soon to be intercooled |
#5 |
its fancy.
HERE--- ![]() http://en.wikipedia.org/wiki/Variabl...y_turbocharger http://videos.streetfire.net/video/V...rbo_191918.htm I could only imagine how AWESOME that'd sound on a 12valve. :guitar: |
#6 |
so does the 6.7 computer control it? Thanks
#7 |
In a nutshell, the computer opens or closes the vanes on the outside of the wheel of the turbo, on the basis of the rpm. Under lower rpms the vanes are somewhat closed therefore creating a small wheel that spools early and fast. As rpms increase the vanes open up, creating a bigger wheel, somewhat a larger turbo.
To me it sounds like yet another thing that could go wrong... the concept is pretty ingenuous though...
__________________
Billut 1992 W350LE SRW Converted to dually; Auto A518 Converted to NV4500 + GV over/underdrive; 4.10 gear ratio; Borgeson shaft; 16cm2 exhaust housing; Stan's 4" turbo back; K&N air filter in OEM box; GDS 60mm 1987 D250LE; Auto; 3.07 gear ratio; bone stock |
#8 |
I Beleive So Yes
__________________
96 3500 2wd, ddp 2’s, 3kgsk, #10 plate. Hybrid over s400 twins, bd full roller bearing trans, DiPricol gauges, bd torq loc and tow loc, Pac brake 4” inline, Straight 4” duals, Aux trans cooler with fan, Firestone ride rite with on board air, gauges, DSS, Centramatics, Maghytec . |
#9 |
havent seen it yet, but i read on a nother forum that some guys are removing the electronic controler and puting a normal wastegate actuator on it to control the vains...
__________________
98 12v 5spd,ddp 90's,62/68/13 over s475,water/meth,19* timing,4gsk,"custom" plate & AFC, 160 pump,2095 plug,60# springs, fass, 5" turbo back,studs,o'rings,dual wastegates,hamilton big stick,SBDD3600,John Deere DV's pensacola injectors in the trash can. 07 mega cab 5.9 G56, smarty, mygig and much more the womans- 02 dually, nv5600 lifted on 37's and more |
#10 |
Man, I'd like to read more about that. Can you fish out the thread where you read about it?
#11 |
i will give it a shot. i came across it when researching my twins build and external waste gate... i think it was cumminsfourm
#12 |
looking at the cummins vgt im not sure if that would work, the control unit looks to be part of the center section, but if some one were to pull one apart there may be a way to do it, on the other hand i have a 06 international service truck with a dt466 and it has the electronic actuator mounted on a bracket with a rod that controls the vains. now i think that would be real easy to set up, but im not sure what this turbo is and dont have any specs yet but migh be worth a shot. and another thought... with the vains completely shut, would it possibly work as an exhaust brake?
i did some searching for thoes threads but only found guys talking about doing it, but i will keep looking. |
#13 |
I was thinking about putting one on my truck, but if you can't control the VGT part with enough precision, it can act as an exhaust brake and possibly cause some driveability problems. That and they are pretty sensitive to soot. Too much soot and they plug up. Lots of Dodge dealerships are replacing/changing the 6.7 VGT turbo's out because they get clogged up.
You can control it with a 14 lb external wastegate or forgo the VGT part and just wire the vanes to where you want them. Tune it for a 20+CM hotside, or crank it down to <12CM for a stick truck. Rig up a manual adjustment for on-the-fly changes. I think it's a neat idea if you have time and money to play around with it. Spend some time in google. Lots of import guy's are using this turbo with some fairly good results. You can find some disassembly photos too.
__________________
92 W250, reg-cab, 220k, HX40/18cm2, pump maxed, 3200 GSK, NV4500, 3.54, 4" turbo back, straightpipe, 4" lift, AutoMeter boost/pyro |
#14 |
Whoever thought a bunch of first gen guys that love their simple trucks would ever look at putting on a VGT turbo fromba 6.7......
#15 |
Yeah, it's almost ignorant. VE guys sure bash the VP and CR guys enough, kind of hypocritical if you ask me. I personally would like to see it done. Anyway to up the power on the pig's is good by me.
__________________
2008 3500 QC/DRW, H&S deleted and tuned, GDP, AFE, Pusher intake horn, Valair, 5" tbe, HBS leveled, Bilstein 5100's, BFG Mud Terrains. Failed G56. |
| Display Modes | |
