555 V8 Cummins any good?
Old 12-26-2003, 09:00 AM
GO 4LO's Avatar
I came across a guy selling a 555 V8 Cummins and was thinking about picking it up. Is this motor any good? I tried finding some info on the web but couldn't see how bomb-able it is. I think it's 185 hp stock, though? Anybody know anything about these?
Chris
Old 12-26-2003, 09:56 AM
Farmer's Avatar
All I know about them is that Versatile used them in their 555 4wd tractors and they were notorious for problems....but I think it may depend on the application. The tractors are usually pulling hard all day long.
Old 12-26-2003, 11:36 AM
shortround's Avatar
Location: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
If it's the one I think it is, it won't even make a good boat anchor. We had a number of them in our 10 ton tractors. They had a nasty habit of coming apart, in a most spectacular manner, when running within a couple hundred rpm's of redline and backing off the throttle. Had one truck that went through 7 engines in less than 10,000 miles. I think ours was rated at 300 hp.
shortround out
Old 12-26-2003, 11:56 AM
GO 4LO's Avatar
Thanks, guys. Guess I'll steer clear of this one, then. He was offering the 555 with an Allison 4-speed for $1500 - guess it was too good to be true .
Chris
Old 12-26-2003, 12:20 PM
thumper 549's Avatar
If it's the kind built about 20 yrs ago leave it alone-Pourn Diesel May offer you some insight (Justin) .
I am not familar with a good one that they made ..Speaking of wierd they even made a flat 6 for busses and the miliatary.Then there was a strate 6 sort of like the 855 series -a little stange also, all good ballest stuff.!!
Old 12-26-2003, 12:22 PM
GO 4LO's Avatar
Thanks for the info and advice!
Chris
Old 12-26-2003, 06:51 PM
pappyman's Avatar
The triple nickel was the forerunner of the 903 cummins....ok for farm use but died for highway use.....too many problems.....they work good in boats at constant RPM's.....I had dual 555's in my 53 ft Matthew's but changed them out for a pair of 903's when one of the 555's dropped a piston
Old 12-27-2003, 03:43 PM
Dave65's Avatar
Had a 903 Cummins when I lived in Florida,it would pull the world but they had a problem,they didn't like to stay together.
I think the 555 in about the same.
Old 12-27-2003, 04:37 PM
gwhammy's Avatar
Thumbs down
Had a triple nickel in a 25 ton linkbelt truck crane, weighed around 58000 lb. When you hit a hill you wanted to skip about 4 gears at a time. Governed out was about 58mph.
Old 01-01-2004, 02:51 PM
signature600's Avatar
I'm with the rest of your, Great farm engine, Bad in trucks. We have one in an Allis Chalmers tractor at 220hp, and it runs like a stripped @$$ ape, but we had one in a dumptruck, Broken Crank.(Oversquare design doesn't like to lug)
Chris
Old 10-31-2012, 08:53 PM
Richard Owen's Avatar
cummins v8 tripple nickel / yale payloader
have loader with cummins v8 not sure which motor it is but seems to have a fuelproblem runs good then dies out after a few moments i check fuelfilters and they are only half full after filling them looking at fuel pump injection pump to see if it is weak tried to gravity feed same result anyone with suggestions
Old 11-03-2012, 11:38 PM
rebal's Avatar
Run away because it will scatter part all over. its one of those engine Cummins doesn't want to remember or claim they even made!
BluesCuda
08-02-2009 09:47 AM
chrisk1500
05-10-2007 11:16 PM
Jim Swantko
02-05-2005 12:41 AM
GO 4LO
07-27-2003 07:41 AM
ouchman
04-07-2003 01:32 AM
Quick Reply: 555 V8 Cummins any good?
