#1 |
4500 Ring Gear
Does anyone know what size the ring gear is and how many bolts holes? Who makes it?
I have called 5 dealers and all they can tell me is, I can't look it up. Need more info from the truck. Can't find any info on various web sites. Thanks Dave
__________________
2006 Dodge 3500 SLT, Cummins, 48RFE, 3:73's, 70 Gallon Transfer Flow Bed Tank with Trax II Monitor System, Racor Marine Centrifigal Water Seperator/10 Micron Filter in the system. Edge Insight w/pyro, Headache Rack, Turbo Wing, Rhino Bed Linner, Nasta Rails, Recon Lights and Strip Lights, Sirius Sat Radio, Net Weight 7,520 lbs with 34 gallons fuel Tagged at 13,500lbs GVW. Towing 35ft Carriage ,Triple Slide 5fer, GVW 14030. 04 Hemi Durango AWD "Grannys Hemi Kid Getter" |
#2 |
front or rear?
rear D110? I'm pulling the center out of a D110 rear this week sometime. I'll let you know what i see.
__________________
Luke --------------------------------------------------- '97 Chevy V3500 CC DRW 6BT 22" Alcoas '98.5 24v 2500 QC 5spd 4wd Demon hot-rod *sold* '90 VW Jetta 1.6L oilbrnr 5spd coupe wolfsburg '73 RS/Z-28 Survivor. |
#3 |
Rear End. Two wheel drive Dodge 4500.
What's a D110 rear? Thanks Dave |
#4 |
The axle that is in the rear of your 4500, I believe is a dana axle
__________________
98.5 2500 QC SB Laramie 24v 5spd 4x4 stock 2002 Audi A4 Sport Quattro 5sp |
#5 |
__________________
#6 |
Thank you very much for the info.
Dave |
#7 |
10 13/16 Front ring gear
11.8 or 12 in the back. Dana lists both. |
| Thread Tools | |
| Display Modes | |
