Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Gen High Performance and Accessories (5.9L Only)
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 11-07-2003, 07:23 AM   #1
gdh11
Guest
4" or 5" Exhuast
I just got an 04 3500 and will be loading it up over time, to include HX40, Propane, Box, etc. I used to have a PSD and ran a 4" exhuast on that. Is there a negative side to having to big of an exhaust and is a 5" too big for what I plan to do with it. I just don't want to put a 4" on and then pull it off only to install a 5". Any comments would be appreciated.
Old 11-07-2003, 09:36 AM   #2
Hoss
Thats MR Hoss to you buddy!
Hoss's Avatar
Re:4" or 5" Exhuast
I've always heard that unless you're going over 500 HP then a 4" exhaust is all you need....or something like that. :-
__________________
Stock: 2012 Laramie 2500 4x4, 6.7 CTD, 68RFE, CC, LB, SRW
Mods: H&S XRT Pro w/Overdrive & EGR/Cooler Delete Kit - Flo~Pro Downpipe & DPF Delete Pipe - HBS 2.5" Leveling Kit & Anti-Sway Drop Bracket - Thuren Rear Lift Shackle - Air Lift Bags w/LoadController - Bilstein 5100's - Nitto Trail Grappler M/T 35x12.5x17 - Ranch Hand Front Bumper, Rack & Rails - Tough Country Rear Bumper - Rigid 30" E Series (Front) & 10" SR Series (Rear) Light Bars - Digital HID Conversions
Hoss is offline   Reply With Quote
Old 11-07-2003, 09:40 AM   #3
Mark Craig
Re:4" or 5" Exhuast
GDH11,
Checkout the last issue of the TDR, there was an article on when 5 inch is needed and soon. Basically they stated that when you get at the 500 RWHp level you would need the CFM capacity of 5 inch, below that it hurt the low end torque response of the the truck. Just an FYI. Call us if you have exhaust questions or visit our site.
Mark @ DPPI
Mark Craig is offline   Reply With Quote
Old 11-07-2003, 12:57 PM   #4
Lil Dog
Lil Dog's Avatar
Re:4" or 5" Exhuast
There is a good thread in the 2nd gen performance area about just this topic. Good information on how the size of the pipe affects performance...
Seems to me the 5" is a waste of dough...
http://www.dodge-diesel.org/yabbse/i...threadid=22079
J-eh
__________________
97 2500 4X4 LWB CC SLT Laramie 5spd LSD 3.55.
Isspro EV's pyro/boost, #10 Plate, PEAK 3K GSK, AFC Spring, DDP III inj, BD Super B Special Turbo, PEAK IC Boots, TAG III, South Bend 13-1.25" Con FE clutch, SCOTTY II-UNI, MBRP XP 4", KDP Tab, 16° Timing, SS DSS / 03TBK, Roda Deaco PAS. Espar D5WSC heater. B-Quiet sound deadening inside.
Dyno 09-2009 405 RWHP / 1050 Ft-lbs
'08 2500 4x4 MegaCab Laramie, 6.7L BlackTEC, 68RFE, 3.73 LSD, Smarty S67-ME, MDKRam air.
Lil Dog is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
