#1 |
hi i have a 3126b marine engine , i am looking to increase power any one have any ideas to increase power or know any shops that can do this
__________________
2003 2500 ho auto quad cab 4x4, h2 rims with 295 toyo mts , rohtech crank sensor , gauges, diablo predator,puck stack , quad boost fooler , boost elbow, htt 62/65/13ss, f1 1.8,gdp pump |
#2 |
Are you sure its not a 3176?
__________________
If your gonna be dumb, you better be tough. (A Quote from my Grandma Grimes) Money isn't everything.................But it sure helps. Do unto your neighbor as he would do unto you.............. only do it first!!!!! (Henry Flagler 1869) 2007 2500 5.9L Cummins Quad Cab Auto 4x4 Shorty Larami Rotella 5w-40 Synthetic Sirius Satelite Radio Home-made Propane Injection Dark Blue 2005 Passat TDI stock (Wife says NO) Several Lister, Yanamar, Duetz, |
#3 |
hi it is a 3126 rated at 420 hp at 2800
#4 |
Wow those marine engines put out horse power.truck engines at the most were 300 my service truck only has 220 and its slow and gutless.I would have to say that engine is set up as hot as it will take.I have not seen any kind of programmers chips ets for cat 3126 engines and for any kind of HP or fuel settings we always have to get a password from cat.Im sure there could be some hackers out there I just ave not looked.
#5 |
cant do programmers its a mechanical engine looking for pump mods , turbo ,injectors
#6 |
I'd say if you want more power than that, you should look at a bigger engine.
__________________
Luke --------------------------------------------------- '97 Chevy V3500 CC DRW 6BT 22" Alcoas '98.5 24v 2500 QC 5spd 4wd Demon hot-rod *sold* '90 VW Jetta 1.6L oilbrnr 5spd coupe wolfsburg '73 RS/Z-28 Survivor. |
#7 |
Are you sure its a 3126b and not a 3116 I thought when cat went to 3126 they were electronic.I work for a Cat dealer I will ask a guy in our compnent shop what kind of mods to do.I think you can set the pump up a little and mess with timing but not much more.
#8 | ||
DTR's "Puttin fires out and workin on big trucks" member...
Quote:
Quote:
3176 was the first all electronic cat engine.
__________________
Tim 2006, 3500 QC/SRW/LB/48RE/4.10/Inferno red, Mag-Hytec trans and diff cover, Isspro gauges, Quad XZTII, GDP 2 micron kit, Air Dog 100, install with pics- http://www.dieseltruckresource.com/d...d.php?t=185809 |
#9 |
there was a 3126E I've seen them. but not sure if it came before or after the 3176. I never liked the 3176 with that huge aluminum intermediate between the block and the head though.
#10 |
It was way after the 3176. Yeah the 2 piece block was not a big hit, it was replaced with the C-10. I have seen those 3176 engines with 1 million miles on them, surprisingly enough.
#11 |
Well my first service truck was a 1995, 3116 mechanical injected,96 was a 3126 electronic next was a 02 electronic and thats my current truck 170000 mile and still going no major problems good ingine just not powerfull.96 was first electronic engine for the 1.1 engine
#12 |
The 3176 was the first Cat diesel designed from the ground up to be all electronically controlled. Mid 1980's.
#13 |
Are you sure its a 3126B? I know its apples to oranges with yours being a marine engine but the 3126B in our D6Ns at work are only rated for about 180hp and are governed to 2300rpm. 420hp?! I think you need a bigger engine but you could ask around for different programming. I know our local Cat dealer doesn't like anything over stock.
__________________
Insert witty remark here. |
#14 |
Registered user
420 is correct for a marine engine. With the fresh water cooling and the keel coolers....
#15 |
cat does not like to tell you anything i have seen a 3126 rated 470 at 2950 but cat will not confirm without serial numbers . looking to find someone that can increase injectors , and find upgrade turbo , i wish it was a cummins would not have this problem .
| Thread Tools | |
| Display Modes | |
