Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > Performance and Accessories 2nd gen only
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 11-01-2002, 04:35 AM   #1
Guest
2500 wheels & tires on 3500 front axles?
I understand that there's a way that 3500 owners can run wider tires on the front -- it has to do with getting &quot;spacers&quot; and then setting up with 2500 wheels. This would be useful for those of us with 4x4's who spend time off road. <br><br>Has anyone done this? Any information anyone can give on how's, problems, who sells it? <br><br>Also, anyone know what an &quot;equivalently-tall&quot; but wider tire size would be for the 255-85 (larger than the stock 235-85) I'm running on the rear duallies? Or is it time to get out the tape measure? <br><br>Thanks. GP
Old 11-01-2002, 06:04 AM   #2
Smokee
Smokee's Avatar
Re:2500 wheels & tires on 3500 front axles?
Just by installing the 2500 wheels, you have &quot;spacers&quot; since the wheels do not have the bud design. They look really cool, but are hard on the side of the truck since they stick out past the fenders.<br>I am not sure, but I imagine that the 2500 on the 3500 hubs would be hard on wheel bearings since the centre of gravity would move outward...chime in, anyone.<br>george
__________________
george
'94 3500. AUTO 354 rear' #4 plate, 3000 GSK, 370's'
BHAF' and 4" Drain pipe 470,000KM
'08 3500 DRW Laramie QC LB 4x4 auto
Silver
WBCCI # 3155
Smokee is offline   Reply With Quote
Old 11-01-2002, 06:56 AM   #3
PaulG
I've seen a 3500 with regular 2500 front wheels on it. They didn't stick out any more than they do on a 2500. I've been told the 2500 and 3500 have the same front axle. The 3500 just uses an adapter bolted to the hub, and the dually wheel mounts to that. In order to put the 2500 wheels on the front, just remove the dually wheel adapter from the hub. Then you can bolt the 2500 wheel directly on just like on a 2500.<br><br>I've not verified this personally since I have a 2500, but after I found this out I checked it against the factory repair manual. From what I could tell, the manual seemed to suggest the same thing. However, I would think it would present a problem in carrying a spare tire, since you have to carry a rear spare and a front one.
__________________
NEW: 2011 3500 SRW CC LB 4WD G56 3.73LSD
SOLD: 04.5 3500 SRW QC LB 4WD 48RE 4.10LSD
PaulG is offline   Reply With Quote
Old 11-01-2002, 07:00 AM   #4
Guest
[quote author=Paul Guthrie link=board=7;threadid=6479;start=0#60388 date=1036155393]<br>I've seen a 3500 with regular 2500 front wheels on it. They didn't stick out any more than they do on a 2500. I've been told the 2500 and 3500 have the same front axle. The 3500 just uses an adapter bolted to the hub, and the dually wheel mounts to that. In order to put the 2500 wheels on the front, just remove the dually wheel adapter from the hub. Then you can bolt the 2500 wheel directly on just like on a 2500.<br><br>I've not verified this personally since I have a 2500, but after I found this out I checked it against the factory repair manual. From what I could tell, the manual seemed to suggest the same thing. However, I would think it would present a problem in carrying a spare tire, since you have to carry a rear spare and a front one. <br>[/quote]<br><br>I agree with Paul, on mine I can take the adapter off and bolt my wheel staright to the hub, but with the daully wheels you have to have that adapter due to the wheel
Old 11-01-2002, 07:08 AM   #5
Guest
below is a link to a trend that shows a 3500 with the front wheels of a 2500<br><br><br>http://www.dieseltruckresource.com/y...;threadid=6473<br><br>
Old 11-01-2002, 07:41 AM   #6
Smokee
Smokee's Avatar
OK. On the 2wd the hub and adapter on the 2d gen are one piece. You can still put the 2500 wheels on...they stick out because they do not have the bud design.<br>They look really cool!
Old 11-01-2002, 03:42 PM   #7
CMN_NOT_STROKN
[quote author=Gear Poet link=board=7;threadid=6479;start=0#60337 date=1036146953]<br>I understand that there's a way that 3500 owners can run wider tires on the front -- it has to do with getting &quot;spacers&quot; and then setting up with 2500 wheels. This would be useful for those of us with 4x4's who spend time off road. <br><br>Has anyone done this? Any information anyone can give on how's, problems, who sells it? <br><br>Also, anyone know what an &quot;equivalently-tall&quot; but wider tire size would be for the 255-85 (larger than the stock 235-85) I'm running on the rear duallies? Or is it time to get out the tape measure? <br><br>Thanks. GP <br>[/quote]<br><br>Gear Poet,<br>The 305/70/16 is roughly the same height but is 2&quot; wider. That may be your only option for same height. A buddy has them on his 2500 with no problems. Just a slight rub on the control arm at full lock on the left. Not sure if you would have this problem or not. Something to look into tho.
__________________
1999 3500 Chassis Cab 4X4 Properly Valved 5 speed 4.10s
255/85/16 Hercules Terra Trac A/T
K&ampN E-1796 as BHAF
Muffler was stolen
Boost &amp Pyro Guages
TST Powermax 2
more cummin...
I'd rather be Cummin' than Strokin'
CMN_NOT_STROKN is offline   Reply With Quote
Old 11-01-2002, 03:48 PM   #8
Guest
Hey, thanks, C_N_S! Good info. And thanks to the rest of you, too! It's all what I needed to know. ;D<br><br>GP
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
