Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 24 Valve Engine and Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-20-2009, 01:24 PM   #1
Fishbait
24 valve CTD no need for valve adjustment..!?
I was just told by a well known diesel shop west of Austin our 24 valve trucks do not need adjustment. In fact tech said it would be a waste of money as they see the trucks "all day long" and have not seen any out of wack.
Furthermore a bastrop dodge dealer said they could adjust them while i waited....thought the motor needed to be cold to do so.
All i know is it sounds clanky and my mileage and throttle response suck bi time with 242K on it.
Confused on this now because i thought the manual (not that service manuals are gospel but...) gives direction to this issue as a maintenance item.
Also one dealer wants 245.00 and the other 149.00 to adjust them. I have not done this but seen the thread with great directions and it doesn't seem to bad....maybe someone in Bastrop or Austin can give some insight on shops etc.
__________________
Fishbait
Besse-Is my Horse hauling, cattlepullin, tractordraggin, boat yankin CTD
2000 4x4 2500 5spd CTD-Ranchhand full front bmpr, Browns Welding 10"rear drop w/lights,Ranchhand full length running boards, Black diamond plate bed rails, Weatherguard Black DiaPlate toolbox, Superchips DBox, AMSOIL synthetics front to back 285/16's-BFG's A/T's, Skyjacker D25's, Bilstein Shocks, Thuren track bar
Fishbait is offline   Reply With Quote
Old 11-20-2009, 01:33 PM   #2
Ruralmedic
I've adjusted mine once, and they were all within tolerance when checked. It's a fairly easy job. With the machinist yet in me, I simply adjusted them to the middle of the tolerance specs as long as I was at it.
__________________
'98.5 black RAM2500 C24VTD Clubcab SLT 4X4 SWB NV4500 3.54 RLSD Lund bug deflector and sunvisor silencer ring removed Westach A-pillar mounted fuel pressure and combo boost/EGT gauges Boss 8'2 V-snowplow Borgeson steering shaft American Racing aluminum rims Jacob's E-Brake Darin's Steering Stabilizer MBRP 4" SS Exhaust BHAF RV275 injectors FASS DDRP
Ruralmedic is offline   Reply With Quote
Old 11-20-2009, 03:36 PM   #3
rich
rich's Avatar
yes they do need adjusting but its like over 100k so would say it wouldnt hurt with that many miles on it
__________________
SIX IN A ROW BUILT TO TOW,CUZ WELL WE ALL KNOW , HAVING A V-8 AIN'T THAT GREAT Dodge trucks that havent made life expectancy
96 3500,-175k 98.5 3500 -164k ,98.5 3500-275k, 01 3500-140k, 03 3500 -155k, 07 3500-68k waiting for possible P-Pump conversion and now I'm killing the 06,3500-116k as of 10-01-09 and counting and yes i make my trucks earn a living buy towing professionally
rich is online now   Reply With Quote
Old 11-20-2009, 03:48 PM   #4
larrybartlett
I have 200k on mine, I'm getting mine adjusted when I have new injectors installed
I've been told the same thing you have but I want mine adjusted (or at least checked)
__________________
2001 1T Quad Cab 4X4, HTB2/62 Street Stock 12CM-62MM Turbo, Volant Air Box, Flowmaster Exhaust, Edge Juice w/Attitude, Goerend Auto, FASS 150 Fuel System, Ranch Hand Grill Guard, B&W Hitch, Monroe Shocks, Timbrens, Borgeson Steering Shaft, DSS Steering Stabilizer, CC Custom Tailgate, Waag Kickouts
A lot of good men have went to Washington, very few have left!
larrybartlett is offline   Reply With Quote
Old 11-20-2009, 04:09 PM   #5
Purplezr2
Should be done cold also. Not hard to do with a couple of hand tools
__________________
98.5 2500 QC SB Laramie 24v 5spd 4x4 stock
2002 Audi A4 Sport Quattro 5sp
Purplezr2 is online now   Reply With Quote
Old 11-20-2009, 06:52 PM   #6
67HotRod
Had mine adjusted at 150K miles when the injectors went in. Had 2 that were a little loose. IMHO peace of mind to least check them, worth the few bucks spent.
__________________
Tow Vehicle: 2001 Dodge Quad cab, 3/4 ton 4X4, 3.54's running 285's with auto. Towing & camper option. 2" level kit, BHAF, Geno's high flow banjos, Holley Blue Fuel pump, 180 STAT, Silencer & resonator MIA and Goerend bros TC/VB, BW trans. Edge Comp, deep trans pan, Boost/Pyro/Fuel/trannny gauges.
67HotRod is offline   Reply With Quote
Old 11-20-2009, 09:12 PM   #7
HecTiK
Do you need a new valve cover gasket after you check them?
__________________
99 Dodge 2500 SLT 4x4, 5spd, Edge Juice w/ Attitude, 4in downpipe 5in straight exhaust, AirDogg150, 35in DuneGrapplers
HecTiK is offline   Reply With Quote
Old 11-20-2009, 09:36 PM   #8
lovinCTD59
lovinCTD59's Avatar
Send a message via Yahoo to lovinCTD59
You can reuse the valvecover gasket. I have reused mine twice so far and no leaks to report. I have done a few valve adjustments on 24V's. Most of them had at least 1 that was past specs.. Its an easy job and there is a write up somewhere around here on how to do it... Piece of mind..
__________________
01.5 HO 3500 Dually NV5600.
Bosch 300 Injectors-BHAF-ATS
Quadzilla Electronics- PDR HX40 Turbo
Dual 6" Mitre Stacks-Holley Blue
GDP Big Line-Auto Meter Gauges
Cobra-Firestik
205,000 Miles
Factory Clutch
lovinCTD59 is online now   Reply With Quote
Old 11-20-2009, 09:38 PM   #9
Nor_Cal_Angler
Nor_Cal_Angler's Avatar
Quote:
To my knowledge No....reuseable
Yes they should only be done COLD...warm or hot motors...metals can be "swelled" or expanded and if you set your screw, once the motor is cold (metals contract) it could be out of tolerance's.
cummins says 150k...
my mechanic says 150k, but will second the OP's mechanic in that 99 out of 100 he does DOES NOT NEED IT once he opens it up.
NCA
__________________
2001.5 24v QC/LB AT AFE, HY, Edge Comp, Banks High Ram, 100 HP Stage 3 Jammers, 4" Turbo Back SS Silverline Exhaust with 5" TIP, FP, Boost, EGT, AT Temp Guages, Frame mounted Holley w/ Big Line, Goerend VB and TD TC
Sky Jacker 4.5 Dual Shock with Rear Add-a-Leaf's Toyo Open Country MT 315's and 16" chrome Ultra Peacemakers
Pioneer Deck, Infinity components, Infinity Rears, RF Punch 10" Subs, RF 4 Channel and MTX 2 Channel
Alarm with Remote Start and Turbo Cool Down
Nor_Cal_Angler is offline   Reply With Quote
Old 11-20-2009, 09:40 PM   #10
jrs_dodge_diesel
jrs_dodge_diesel's Avatar
Quote:
I agree, the gasket is reusable (it's rubber), just take care not to tear it when pulling the valve cover.
It's fairly easy to do, and only takes a couple hours.
Here's the how-to guide:
http://www.dieseltruckresource.com/f... onlynewfaq=1
__________________
J.R.
U.S. Coast Guard , Electronics Technician 1st class
Extra class Amateur radio operator - K5DTR
2001½ SLT 2500
2WD, auto, short bed
Hi-flow banjo bolts
Scotty Air II with the cowl hole and no silencer ring !
Isspro EGT (pre-turbo),fuel pressure, boost, and transmission temperature (sensor in hot line) guages
jrs_dodge_diesel is offline   Reply With Quote
Old 11-21-2009, 06:00 AM   #11
00 CTD
Cummins says 150K on the adjustment. The gasket can be reused as long as it's not torn.
__________________
"00 SLT 4x4
Slightly modded
00 CTD is offline   Reply With Quote
Old 11-23-2009, 11:21 AM   #12
01RAMer
01RAMer's Avatar
Quote:
Question is did the valves back off or is there something building up on the seats not letting the valve close all the way? I though about adjusting mine but wonder if I found one, could it be a bad valve seat. Adjustment under this situation would just enhance a leaking valve. How about the thoughts of others?
__________________
01.5 - 3500 Dually 5-speed, 4x4,
Egde Juice w/ Attitude, SS Track Bar, DSS, MBRP 4in Exh, Fuel Transfer Pump Retro ,2 WD Low Sw
Reese Gooseneck & 5th wheel Hitch w/ in bed elec connector
Elec Flip Tow Mirror Conversion, Mack Trk Air Horns
37ft 5th Wheel Montana 3400RL, 4 slids, Onan Genset, w/TrailAir Pinbox
01RAMer is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
