Go Back   Dodge Diesel - Diesel Truck Resource Forums > Emergency! > HELP!
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 11-16-2009, 03:26 PM   #1
hiatt426
24 valve charging problem
So I have a 98 24 valve that has a new alternator, new terminal ends, and new batterys. it will stay charged, but it doesnt charge it any more than 9 or 10 volts. im thinking it is a bad voltage regulator. so any help is appreciated. oh, it does have an engine out of a 2000, i dont know if that would affect much of the problem or not.
hiatt426 is offline   Reply With Quote
Old 11-16-2009, 05:39 PM   #2
cmac
cmac's Avatar
Send a message via MSN to cmac Send a message via Yahoo to cmac
you might want to check the crank sensor. i'm pretty sure that it can cause a low or no charge situation.
__________________
98 12V QCLB 4x4 Auto (BDtorque converter, valve body, shift kit and power lock)
K&N CAI with Amsoil filter, S300 w/ 4in STR8 pipe
Bosch 370, custom fuel plate, 204 DV's, 3KGSK
Boost EGT and Tranny Temp gauges.
DYNOed @ 343 HP / 764TQ 1/8th Mile ET 9.90 @ 73MPH
Quote:
Originally Posted by 19mike92 View Post
If you can't have a cummins. You might as well just get a bicycle. Might I suggest a 10 speed with tassles?
cmac is offline   Reply With Quote
Old 11-16-2009, 07:18 PM   #3
hiatt426
so just to help diagnose things I just ran my own wire on a toggle to the field supply post on the alternator and it charges just fine. but the "check guages" light still comes on. I dont care too much about the truck, I think i will just put on a diffrent voltage regulator. what are your thoughts?
Old 11-16-2009, 08:34 PM   #4
cmac
cmac's Avatar
i thought these trucks have internal voltage regulators?
Old 11-16-2009, 09:08 PM   #5
rebal
rebal's Avatar
Send a message via Yahoo to rebal
check all your grounds and connections the pcm can cause a no /low charge too
__________________
1990 W250 bought new in Nov. 89 performance built 727 and torque converter , high miler 700 k heavly bombed kelderman air ride
2001 2500 HO 6spd 4x4, Engine brake , mad.ecm mach1.6s fass,SBC 4" turbo back exhaust BHAF fluid damper,ARP head studs, DSS, Fast cools.snow w/m, wife says trucks fast enough:( 335 hp/800 tq)
How many of your rights are you willing to give up before you feel totally safe ?Wake Up People vote EVERYONE OF THE BUMS OUT OF OFFICE!
rebal is offline   Reply With Quote
Old 11-17-2009, 08:22 AM   #6
patdaly
Quote:
Internal to the PCM...........
__________________
"Brownie"
1997 2500 Ext.cab SLT, 4X4 auto, 3.54 gears, posilock, 98/99 steering conversion. New TC, lovin her again!
"Greenie"
1997 2500 Ext. cab SLT, 4X4, NV4500, 3.54 gears, Ready to install SB DD3250, built just 216 trucks after Brownie!
patdaly is offline   Reply With Quote
Old 11-17-2009, 08:34 AM   #7
cmac
cmac's Avatar
Quote:
well now that aint no fun...
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
