Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 4500 / 5500 - Chassis Cab Trucks
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 07-27-2012, 10:14 AM   #1
CoastalDav
CoastalDav's Avatar
2008 4500 Fuel Tank Vent
I have a friend that is a fulltimer, with a 2008 4500 that continually has problems when filling the fuel tank. It spits and burps not allowing him to get it full. I looked at all the TSB's and searched this forum without any luck. One TSB talked about debris getting into the vent causing poor performance. Nothing specific when fueling.
Has anyone else had this problem? Fixes?
Thanks in Advance
Dave
__________________
2006 Dodge 3500 Bighorn SLT, Cummins Super B, 48RFE, TFI Triple TC, Jake Brake, Air Lift, 4:10's, 70 Gallon Transfer Flow Bed Tank, Trax II Monitor, Racor Marine Water Seperator/10 Micron Filter. Edge Juice/Attitude, Headache Rack, Turbo Wing, Rhino Bed Linner, Nasta Rails, Recon Lights and Strip Lights, Sirius Sat Radio, Net Weight 9,040lbs ready to tow, Tagged at 13,500lbs GVW. Towing 35ft Carriage, TST, GVW 14030. Full Timin, Carriage Travel Club 17771
96 Cummins 12V
CoastalDav is offline   Reply With Quote
Old 07-27-2012, 11:52 AM   #2
Colo_River_Ram
With age comes the cage
Colo_River_Ram's Avatar
The only problem I have filling mine is that "Green-Armed-Bandit" keeps robbing me. I fill from the back though a 90 as well..
Do a search for "vent mod"
__________________
11- "BRP" Can Am Commander 1000XT SxS (Stress Therapy Unit)
08-Sterling Bullet 5500 4x4,6.7,188.5,Q.Cab,White,Custom Built Flat-Bed,6sp Aisan,4.88's,P-3,PTO/Snow Plow Prep.
05-3500 4X4.5.9 w/Jake, Hi Idle Enabled,Steering Upgrade, Bilstein Y&B's, Big Horn, L.B,Q.Cab, G56 SRW.3.73 LS, Custom Bed Rack w/Tool Chest.Line-X OTRBL, B&W T.O.B.,P-3 W/Valley "V30137" In Bed Harness. 2x 1260 Amp Deka Grp 31's
01-Cat/EP 4x4 Forklift, 4.2L Perkins
42' 28.5K GN El/Hyd Disc Brakes
32' 16.5K GN
Colo_River_Ram is online now   Reply With Quote
Old 07-27-2012, 12:09 PM   #3
CoastalDav
CoastalDav's Avatar
Thanks for the info. Your post was the only thing that showed up in the forum search. Figures.
Dave
Old 07-27-2012, 12:22 PM   #4
Colo_River_Ram
Try putting a "Tank" in front of the vent mod, there is several good threads on the subject. What kind of bed does he have on it? the only thing I can think of is they pinched the fill or vent hose on the install.
Old 07-27-2012, 12:27 PM   #5
CoastalDav
CoastalDav's Avatar
Can't find any threads of the Vent Mod. He has a hauler bed on the truck.
I just told him to get under the truck and look. He's not very mechanically inclined and has a bad back.
If you know where those threads are, I would appriciate a link.
Dave
Old 07-27-2012, 04:45 PM   #6
Colo_River_Ram
Here is a PDF from Glacier Diesel on their kit for the standard truck, it should be similar for the C&C (call them to verify):
http://www.dieseltruckresource.com/d...2&d=1299097819
The C&C came with a bag that had a couple of hoses for fill options, this is the one(stock 90) that I used:
Click the image to open in full size.
Note:
The vent hose was longer than needed so it could be cut to size on final install.(this might be where the problem is)
The wire is the fill spout ground wire.
Go to post 22 here and click on the small photo for a slide show of the bed build, towards the end of the show is the hose hookup:
http://www.dieseltruckresource.com/d...t213006p2.html
Old 07-28-2012, 11:21 AM   #7
CoastalDav
CoastalDav's Avatar
Thanks for the info. That was a good slide show if for nothing else on how to build a bed. The one picture of tank top and its connections, may or may not help my friend. I sent the thread to him last night. Have not heard anything yet.
Thanks again!
Dave
Old 07-28-2012, 11:46 AM   #8
Colo_River_Ram
Your Welcome,
Ill bet you a quarter they did not trim the vent hose or they crimped it during the installation.
Old 08-12-2012, 10:41 AM   #9
Colo_River_Ram
Any update on this?
Old 08-12-2012, 11:02 AM   #10
CoastalDav
CoastalDav's Avatar
The owner of the 2008 4500 looked at the fill hose and indicated it had a dip in it to clear the bed. I told him that was most likely why he's having problems fueling.
He has not replied any further to date. Will check it out and see what going on.
Dave
Old 08-13-2012, 08:22 AM   #11
RamGazer
RamGazer's Avatar
Check out this post. This might be what your friend is looking for. Scroll down to post #5. Good luck.
http://www.dieseltruckresource.com/d...k-t299151.html
__________________
2006 Dodge Ram 2500 SLT Mega Cab, 2x4, 3.73 Rear End, Cat Removed, Tekonsha P3. Patriot Blue with a Roll-N-Lock bed cover, (sometimes pulling) 25' Joey Layton Lite T.T.
Megacab Club Member #334
RamGazer is offline   Reply With Quote
Old 08-14-2012, 04:15 PM   #12
CoastalDav
CoastalDav's Avatar
I got an email from the owner of the 4500. Here is want he had to say;
"I've started putting two orange levelers under the side of truck accepting diesel. This makes some elevation down to the fuel tank. Last fill up guy next to me said they carry a two by six on there flat bed to help when filling there trucks. Had a guy who owned tow trucks say the same thing. Another guy said they fed gas into another hose (farm trucks) which allowed more drop into tank. Sounds like this is a common issue with flatbed or western hauler bodies. It must be an issue with elevation or not having enough drop between entry point and fuel tank. It feels strange putting blocks under tires and sometimes that doesn't seem to help."
He's currently headed to Rapid City after visiting Devil's Tower.
Don't know if he plans on doing anything else with the vent or fill hose.
Dave
Old 08-14-2012, 07:51 PM   #13
Colo_River_Ram
Dave,
Thanks for the colorful update..
It must be the western bed as mine fills with no problem even with the big pumps at the RV stalls.
I guess I owe you a quarter
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
