Go Back   Dodge Diesel - Diesel Truck Resource Forums > 3rd Generation Ram - Years 2003 and up > 3rd Generation Ram - Non Drivetrain
Register FAQ DTR Store Members List Mark Forums Read
Thread Tools Display Modes
Old 05-01-2007, 11:24 PM   #1
tincan
2007 remote door lock horn chirp
I am trying to disable the horn chirp when I use the remote door lock. I followed the manual exactly and it did not work. I tested the horn chrip after each attempt and it's still there. Does anyone with a 2007 have any advice?
__________________
2007 Silver Big Horn Edition 2500 SLT SB 4x4 5.9L 48re
Use to be --> Bone stock
Now --> Smarty Jr., Pricol EGT gauge...that's all I need for now!
tincan is offline   Reply With Quote
Old 05-02-2007, 06:39 AM   #2
schv
schv's Avatar
For some reason, the method described in the owner's manual doesn't work on the `07's. The dealer can do it for you - should be free of charge (mine was).
__________________
2007 2500 Quad Cab Laramie H SB 4x4 5.9L 6sp Electric Blue, SRT-10 hood, Line-X, BakFlip tonneau, N-Fab, Smarty, KORE Recon, Thuren track bar, Thuren steering stabilizer, Carli swaybar links, DSS, 18x9 (5" b.s.) Centerline Grizzly's, 35x12.50 Toyo M/T's, Bushwacker flares
schv is offline   Reply With Quote
Old 05-02-2007, 07:42 AM   #3
emf480v
emf480v's Avatar
If you have the overhead computer, you have to disable it from there. I tried
for two days doing it through the key fobb until I read a little more in the
manual. It has a bunch of other settings also like auto door lock, un-lock on
exit, etc.
Good Luck
__________________
2007.5, 3500 4x4 QC Dually SLT, 6.7L, 3.73's, 68RFE, Thunderoad, Quadzilla Commander (for monitoring only)
Dual mesh grill, air-lifts, 988 springs, ARE lid
Inferno Red, Khaki int.
emf480v is offline   Reply With Quote
Old 05-02-2007, 09:34 AM   #4
Rob Mitch
Rob Mitch's Avatar
I have the overhead computer on my 07 6.7 and the manual gave a good explanation about turning that off along with a number of other features. One thing I didn't see there is the ability to turn off the "Panic" feature on the key. I had some how turned that on twice so far. This truck has a really good horn on it! This was an easy fix though in the key.
__________________
2007 6.7, 3500, Single rear wheels, Quad cab, 4X4, 6 speed manual, Inferno Red, B&W hitch with 5th wheel compaion hitch.
6th generation Texan
Rob Mitch is offline   Reply With Quote
Old 05-02-2007, 11:12 AM   #5
tincan
Thanks for the help. I would like to to do it myself because it's not convenient to go to the dealer. I read the manual and it does not explain how to disable this feature in the overhead console section. Can someone tell me what page to read in the manual? It can't be that difficult. I must be an idiot!
Old 05-02-2007, 01:01 PM   #6
Rob Mitch
Rob Mitch's Avatar
On my 2007 6.7 this is located in section 3 of the owners manuel. Start on page 150 for info on the overhead console with (EVIC) On page 153 it gets into "Personal Settings" On page 154 it gets into "Sound Horn With Lock--Yes---No"
I hope this helps.
Old 05-02-2007, 04:38 PM   #7
tincan
I have the 5.9L and my manual must be different than yours. There is nothing about personal settings with the overhead console. Can you tell me the procedure? Send me a PM if this is getting too drawn out. Thanks.
Old 05-02-2007, 04:52 PM   #8
dbunhook
I have a 2007 5.9L and cannot find the information on programming the overhead computer in my owners manual. Perhaps this is a feature availble for the 6.7L engine only.
I have tried everything short of returning to the dealer to get the horn chirp turned off. Nothing I have found works.
If you care to post the information from the 2007 6.7L owners manual, I would love to give it a try on my truck.
__________________
2007 3500 DRW 5.9L 6spd
dbunhook is offline   Reply With Quote
Old 05-02-2007, 09:45 PM   #9
Rob Mitch
Rob Mitch's Avatar
There likely is a difference in the 5.9 and the 6.7 so the procedure probably won't work, but I have scanned the pages about this if you want them. I don't know how to post pictures here. I could email them to you or maybe someone could voulenteer to post them.
Old 05-02-2007, 10:11 PM   #10
Rob Mitch
Rob Mitch's Avatar
Tincan, I think you tried to send me a message but it didn't open on my end.
Try this email address for me; RLMitchell@hot.rr.com
Old 05-02-2007, 10:16 PM   #11
Ramyes
I tried over and over to get mine to stop honking on door lock, all it did was p*ss the neighbors off. finally took it to the dealer, took them about ten minutes with thier scan tool.
__________________
2007 Ram 3500 5.9 CTD mega cab DRW 4x4 Auto SLT Jake Brake
Ramyes is offline   Reply With Quote
Old 05-02-2007, 10:28 PM   #12
tincan
I called the service manager at the local dealer and he said the techs use the scan tool to disable the horn chirp. I asked him if you could do it with the key FOB and he said he wasn't sure. I'm going to wait to see if anyone else posts a solution.
Old 05-02-2007, 10:45 PM   #13
DaveB.inVa
DaveB.inVa's Avatar
You might be able to get somewhere with using the 6.7 procedure on the 2007 5.9. They made a change about midway through 2006 with the computers and such. This is the reason so many box manufacturers such as TST are having trouble with trucks built after about the middle of 2006.
Also if you have a 2007 5.9 take a look in your fuse box. There is a lot of stuff in there that is associated with the 6.7. One I remember right off is the fuse for the VGT turbo. My 5.9 has this and some other stuff, but no VGT!
__________________
2007 (Built: Midnight 12/5/2006) 2500 Black Quad Cab SLT Short Bed 5.9, 4x4, AE G-56, 3.73LS, Free Air Box Mod, Cool Hose, CORSA 4" Exhaust, 5" MBRP Exhaust Tip, ISSPRO boost and EGT gauges, Westach fuel pressure gauge, Glacier Diesel GFS 392 Performance fuel system, Glacier Diesel 2 micron filter kit with CAT 1R-0750 filter, Smarty aftermarket injector/stock TM set on SW3, Quad Boost Fooler, Block Heater Cord, Defiant steering brace, Free Fogzilla Mod, Air freshener that really works
DaveB.inVa is offline   Reply With Quote
Old 05-03-2007, 12:01 PM   #14
dbunhook
I sure would like to have the 2007 6.7L instructions. Please email them to dbunhook@hotmail.com. Thanks.
Old 05-03-2007, 07:53 PM   #15
dbunhook
Thanks Robert for sending me the manual pages.
The method described there would not work. I do not have the same model of overhead display as I do not have the Program Button described in the manual. My display even looks different.
I guess I will have to go to the dealer as there is nothing I can find to disable this feature. I have been putting this off for 6 months as I know the dealer will try to charge me and that they will need to keep the truck for a day (or two) just to change this option. Shoot, it will probably come back with a new problem caused by their work. Maybe I will just live with the horn chirp.
I just wish it worked like described in my manual.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2003, DieselTruckResource.Com
