Thread Tools | Search this Thread | Display Modes |
#1 | ||
2007 2500 and 3500 SRW Center Caps.
__________________
2007.5 Dodge RAM 3500 Laramie MegaCab 4x4 SRW Laramie 2FH Pkg, 6.7L CTD, 68RFE Auto, Electric Blue Pearl Coat, Leather Trimmed Bucket Seats in Slate Gray, Front Hood Protection, Anti-spin Differential, AM/FM/cass/6 disc CD w/SIRIUS Satellite Radio, Clearance Lamps, Under Rail Bedliner, Single Rear Wheel Group, Trailer Tow Mirrors, Power Sunroof, Diesel Exhaust Brake, EDGE Insight, 20x9 Ultra #214 Chrome "Grinders" wrapped in LT305/60R20 Wrangler SR/A's. MegaCab Member #98 |
#2 |
Must be an 07.5 and up thing the ones on my 07 are metal...
__________________
Chris 2007 Ram 2500, grey, 4x4, 5.9, BMK11 oil bypass, g56, gear vendors od, 285/70/17, freespin hubs, gauges, smarty jr, 6" intake, no cat 4" hi flow muffler, all led's 2003 Kenworth T600, black, MBN C-15 "CAT by Kurt", 6NZ 550hp/1850tq Brakesaver flash, fuel temp wire, Borg Warner non-waste gated turbo, 13 speed, 3:70 rears, dual 6" pipes, high flow mufflers, full gauges, 2006 Utility53' dry van, e-tracs logistics posts, air slide tandems |
#3 |
Mine is from 12/06 and has the plastic.
#4 |
Yours was the last batch of 2007 5.9's mine was a June '06 build date. Those 12/06 built 5.9 trucks also got the good g56 trans with the slightly higher sixth gear ratio like in the current 6.7L trucks. If the plastic ones give out on you the good ones with metal rings can be had from ebay for pretty cheap. I lost a hubcap and bought a replacement there for $17.
| Display Modes | |
