Go Back   Dodge Diesel - Diesel Truck Resource Forums > 1st and 2nd Generation Ram - Years 1989-2002 > 2nd Gen. Dodge Ram - No Drivetrain
Register Forgot Password?
Search
submit to reddit
Thread Tools Search this Thread Display Modes
Old 03-19-2007, 08:09 PM   #1
matthopp
matthopp's Avatar
2002 Hubcap / Wheel Cover
It seems like my hubcap has disapeared; i would like to believe it fell off somewhere but i have a hard time believing that, the other 3 seem very tight. Anyways, suggestions on finding a replacement? I checked the junkyards and all of the 3/4 tons were missing hubcaps. I keep checking ebay and Mopar Wholesale but no luck. Can these things actually just fall off or did someone see dollar signs?
__________________
2002 2500 Cummins 5-spd, Quad Cab Long Bed, Laramie, Dk Garnet Red, Rhino-Over the Rail, Ranch Hand Grill Gaurd, Gooseneck, Cab Lights
Fightin' Texas Aggie Dodge CTD! Whoop!
matthopp is offline   Reply With Quote
Old 03-19-2007, 08:12 PM   #2
scottsjeeprolet
scottsjeeprolet's Avatar
I had to buy one on Ebay once. they aren't too cheap either.
__________________
1999 3500 4X4 DRW, QC, LB, Auto, 4.10 posi rear, 235 85R16 Dunlop RV, S&B Intake, Adrenaline w/Pulse, ISSPRO guages, AirDog 100, BD VB & TCI Maximizer TC, B&M Super trans cooler, ATS Co-Pilot, HX 35/40, F1 Mach 3's for tailgaters to enjoy
Scotte
Maryland DTR Chapter #33
Wanna join? PM me for details.
Find out what's going on in MD Chapter #33 Forums
scottsjeeprolet is offline   Reply With Quote
Old 03-19-2007, 08:12 PM   #3
phox_mulder
phox_mulder's Avatar
Quote:
You'd think they'd take them all, not just one.
They "lock" onto the lug nuts, if one of the ones it happens to lock onto was loose, I could see it falling off.
No idea where to find them.
I think mine are safely stored on the side of the garage.
phox
__________________
2002.5 Dodge Ram 2500 4X4 SOLD
2009 Jeep Wrangler Unlimited X 4x4.
Detonator Yellow in color
Bone stock for now, at least for a couple months
2008 Harley Davidson FLHR Road King.
Black Pearl in color
12 inch apes, stainless cables, Vance & Hines pipes, garage door opener, combo speedo/tach
phox_mulder is offline   Reply With Quote
Old 04-13-2007, 09:59 AM   #4
matthopp
matthopp's Avatar
Well I bought a new hubcap from wholesale mopar and put it on two weeks ago; I lost the new one on the same tire as the old one. I have the timeline pinned down and find it very hard to believe that they were stolen; I also drove the route again within two hours of noticing the missing cap and couldn’t find it.
Any ideas on why/how I could loose two hubcaps from the same wheel in a three-week period? Wheel/rim problems? At roughly $70-$80/ea, I want to find the cause other than just bad luck. On the other hand, I believe in keeping the truck up and uniform and don’t having the hubcap missing.
Old 04-14-2007, 04:30 PM   #5
NMCTD
NMCTD's Avatar
Heres a few places you can look into new/used ones.
http://www.hubcaphaven.com
http://www.hubcaps.org/index.html
http://www.hubcapzone.com/?gclid=COO...FSOZEAodUBOLgw
http://www.hubcapkingdom.com/
http://www.ehubcap.com/?wcw=google&g...FSR6EAodK0sqeA
__________________
1997 RAM 3500 4wd 5speed, Isspro Gauge's, Custom Fuel Plate, AFC "mods", straight piped, BHAF, Valair HD clutch, DSS, 03 track bar, PSC steering.....
NMCTD is offline   Reply With Quote
Old 04-17-2007, 08:47 AM   #6
greenworks
greenworks's Avatar
OK fellas here is the answer as I was losing hubcaps faster then I was changing gotch . the last one I bought at dodge I put it on in my garage drove 1 block and saw somthing pass me.....yep new hubcap . Two of the things I do know is when my truck gets a wheel rotation leave the caps off for a week and retorque several times, I have found the lugs loosen up letting the wheel flex to much causing the cap to pop off. lastly once everything is tight apply a rtv silicone or similar to the hub caps where they meet the lug nuts use enough so that when you bang on the hub cap it squishes out the side of the clamps you won't see it being it is covered by the hub cap. Finally try not to drive it for a day to let the silicone set on then drive your heart out has worked for me for over a year ...
Jason
__________________
2009.5 2500 MegaCab, Laramie, 6.7L auto
Past Truck 2001.5 2500 CTD 4x4 SLT
Comp, FASS 95gpm w/ filters,Draw Straw, 4" Exhaust,EDM(155hp), S-300 Super B Turbo,TAG III, Scotty II w/ hole/uni, HD Apps, Autometer - (Pyro-Boost-FP),SBC 3600 Sprung DD, 1 3/8" input shaft, SB Upgraded hydraulics, BD short shifter, MAD ECM, 3rd gen badges/Power Towing mirrors, Colour matched Line X bed,rockers,front and rear bumper,DSS - 03 TRK Bar and a few other perks;)
greenworks is offline   Reply With Quote
Old 04-17-2007, 09:30 AM   #7
yfz450guy
yfz450guy's Avatar
yes, they can and do fall off. i got tired of losing them so i took the rest off.
this was my method for the fix..............
Click the image to open in full size.
__________________
2001.5 ram 3500 dually, 4x4, long bed, quad cab, BHAF. auto trans, 4:10's, rip rook 4" pipe, 4040 aero turbine muffler, fass fuel pump.
03 jeep liberty
08 denali fg3100
93 bullet 21xd, 08 etec 250ho.
current top speed 89.2 mph.
yfz450guy is offline   Reply With Quote
Old 04-17-2007, 09:32 AM   #8
ScottN
I haven't had any problems... when one got damaged, I bought a used generic replacement for about $20 CAD. It doesn't have the Dodge logo, but before I get too picky, I should probably fix my rust spots :P.
A whole new set of the generic ones was about $50-60 CAD, I believe.
I make sure to boot them on with my foot, to make sure they are seated. Never had one come off - they look like they'd stick on quite well. From an inspection perspective, the things suck, since you'd want access to the lugs. to check for looseness/rust staining (sign of looseness).
__________________
1997 2500 SLT Laramie, CTD, 4x4, long box, ext. cab, 5 speed, red/tan
225/65R19.5 Michelin G622 tires, Boost, Pyro, FP gauges, 4" exhaust, Wesbasto TSL-17, Luk ProGold clutch, Dodge seat covers, K&N, sweet trailer wiring, sweet fuel shutdown cable, sweet winter front, sirius satellite radio, 2-channel amp, Pioneer speakers throughout, DSP fifth wheel
ScottN is offline   Reply With Quote
Old 04-17-2007, 09:45 PM   #9
Eat Beef
Eat Beef's Avatar
Location: Alberta Foothills - Power to grow with 6 in a row - XLR8
What did you use for center caps?
__________________
2005 3500 QC 4x4 Dually, SLT Sport, NV5600, 4:10's, E-Brake, Linex, B&W Companion, Smarty Jr (SW3,TM2,TQ2), Aux. Fuel Filter.
2003 2500 QC 4x4 LWB Laramie-------SOLD
1997 3500 CC 4x4 Dually, SLT Laramie, NV4500, some mods--------SOLD
Eat Beef is offline   Reply With Quote
Old 04-17-2007, 10:41 PM   #10
yfz450guy
yfz450guy's Avatar
i got the nut covers from a big rig chrome shop along with the center caps. the nut covers are 15/16 flanged and the center caps are some old stock of air horn covers. the rears just snap over the axle bolt heads and the fronts i fabbed up some brackets and welded them into the front hubs and pop riveted the caps to the brackets. there was alot of r&d involed in the center caps. for the paint i used vht engine paint in semi gloss and it has held up alot better than i expected.
Old 04-17-2007, 11:42 PM   #11
Eat Beef
Eat Beef's Avatar
Thanks. Those look good.
Old 04-18-2007, 07:33 AM   #12
Joe Diesel
Joe Diesel's Avatar
I lost 2 caps bought them at the dealer $125CDN each after those fell off I took the other 2 off. I did buy an aftermarket set but they were the reintaining ring kind 94-99 who knew they changed the caps ...I'm still trin' to sell those.
Nice set up yfz450guy
__________________
02.5 25004x4 Sport,4:10,Silver,Quad,shrt bx,47RE HD Auto,Tow Pkg, SLT,Roof Lites
Custom: HIDs,Custom Grill,Custom console for,Scanner, CB,ScanguageII.Firestik & Wilson antennas, Isspro FP, EGT & Boost Gauges,bOmbsSkyjacker Springs,Bilsteins,Custom ScottyII,Thuren,Dual 6" StovePipes,DSS,Drag Comp,FASS HPFP,VP44-X,MACH4,HTT 62/71,DTT 89%,Opie IP,BD black,Trans-Go
#s 572Hp 1670TQ 333k+
Joe Diesel is offline   Reply With Quote
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
vB.Sponsors
Copyright 2011, DieselTruckResource.Com
Contacts Backup
