Thread Tools | Search this Thread | Display Modes |
#1 | ||
2001 tranny ?
#2 |
Two separate problems!
Slipping is sign of maybe needing a rebuild.... but the not shifting out of first is probably the 'Govenor Soleniod'... and may need a 'Pressure Sensor' (or transducer) as well. These are an easy do it yourself replacement, requiring just dropping the pan, and about $200.00 in parts for both. RJ
__________________
02, 2500, QCLB, 4x4, Auto, 3.55 Power-Lok LSD - DTT/Billet - Smarty- Mach 4's - BD Twins - O-Ring/Studs -Snow's H2O/Meth - FASS - F-1 Cam/Valve Springs - HTT Manifold - Road Armored - 5" pipe - TC Lockup Switch - 3rd Gen Brakes, Wheels & Trackbar - Fluidampr - DSS - 33" Pro Comp Xtreme A/T's |
#3 | |
sensor
Quote:
#4 |
Mine didn't. My symtoms were it would start out in 2nd or 3rd and stay in those gears. FYI, if you do it yourself be prepared for an ATF bath. I tried letting one side of the pan down to drain it but still had it everywhere. Like Row said, it's a pretty straight forward job and even a Caveman could do it.
__________________
Mine 2001.5 Dodge Quad Cab 4x4 Auto Cummins HTS Ultimate Duty Tranny, Straight piped, Puke bottle relocation, Stage 3 Nozzles, BD J Hook, Vulcan Big Line/Relocation Kit, FASS DDRP, Quadzilla XZT+, Lock-up Switch Dipricol Optix trans, pyro, fuel pressure on A pillar, Boost gauge in cubby hole Jordan Ultima 2020 Hers 2003 Jeep Liberty Sport 3.7L Ours Coachman SOA 299TT 1978 Glastron Carlson (115 Merc, Hotfoot, completely restored) '09 Polaris RZR |
#5 | |
tranny
Quote:
Thanks |
#6 |
No codes here either.
Just drop pan the night before and remove filter. Let it drip all night. Both are on passenger side, bottom, front of valve body. Takes 4 bolts and 2 hex screws (T-25).... if I remember correctly. Very straight forward. If you can't see them clearly and easily figure out how to R&R them.... rebolt pan and take it to tranny shop. But a beginning mechanic could do it very easily. RJ |
#7 | |
Tranny
Quote:
If that doesn't work, what is the best aftermarket tranny. They all look good NADP,BD, ATS,DUNRITE, DTT?
__________________
"LIVIN RIGHT AND BEING FREE" 05 3500 dually six speed quad cab 4x4 flat bed bone stock except open 4" exhaust. |
#8 |
Send a question off to John at www.coperacingtrans.com, look on his web site and ask him what he thinks, or call him around 5PM central time at 219-374-0100. He does nothing but Mopar transmissions, mostly racing stuff, but he did my '01 and it has been fine since. Todd
__________________
2001 2500 Quad cab, SLT Plus, 4x4 shortbed, auto, with 3.54 anti spin gears, and 285/75/16. Leather, heated seats, lots of power options. Bridgestone dueller a/t's, 6720 lbs empty. |
#9 | |
Quote:
Do a search and be prepared for a lot of reading. The only one I can comment on is the HTS cause that's what I have. A stock tranny was $2800 and the HTS with all the goodies was $3400 (plus $250 shipping). Well worth the extra $$$. Anyway, go with a trusted tranny and you won't have any problems. |
#10 | |
Quote:
We've had too many 'Tranny Wars' over questions like that.But I would stay with the big three.... DTT, HTS or Goerand. All seem to have very few complaints. JMO RJ |
#11 |
tranny
Thanks for the input, very helpful.
#12 |
Because of your location, I will say this.
One of the most reliable tranny rebuilders on this web site is about 2 hrs from you .... and well worth talking to. TIMinVA....HERE Good Luck! RJ |
#13 |
Back to orginal. When you replaced fluid, was there any stuff in pan? Did the magnet look like a chocolate Krispy Kreem donut? If there was material on magnet or fllter then the clutch was slipping. The 1st gear clutch only slips a few seconds and is history. Either burn out or welded together. Won't pull at all or stays in low gear. This does not seem to be your case. Works correctlly occasionally, correct!! From what have read from your description, you need the governor pressure solenoid. It is sticking open occasionally, hence no upshift. Decides to work and all is well on shifting, right!! Suggest the transducer at same time as dificult to determine which. JMHO
__________________
2008 1/2 3500 dually that is stock except for 2 micro inline filter for fuel. Infero red extended cab, long box made for highway towing. |
#14 | |
tranny
Quote:
#15 | |
Quote:
Dealer item so take your checkbook. You might try wholesalemopar.com. I've some $$$ in the past on parts from them. |
| Display Modes | |
